Question about HP Workstation Xw6000 PC Desktop
Installing windows xp on a hp workstation xw6000 cannot find hard disk drive
  • 1602 Answers
SOURCE: windows vista drivers for hp workstation xw6000
WINDOWS DRIVERS
WWW.WINDRIVERS.COM/DRIVERS
WWW.DRIVERSHQ.COM
WWW.HP.COM/DOWNLOAD/DRIVERS
ROD
Posted on Mar 13, 2009
map9966
  • 2351 Answers
SOURCE: Installing Windows XP on new drive in HP a220n
Your new hard drive has a name, like Seagate, Western Digtail, bla, bla... Go to the Mfg's web site for your drive. Download the bootable floppy disk manager setup utilities. If you have a floppy disk drive. If you don't have a floppy drive most Mfg's allow you to make a bootable CD. Lastly or maybe I should have mentioned this first. Make sure your drive is pinned out correctly. I'm only guessing you bought an IDE drive which has a jumper for setting the drive as a master or a slave or a master with a slave.
Posted on Jan 04, 2008
  • 44 Answers
SOURCE: i have just purchased a
just do this.go to c-mos setup by pressing F2 select SATA operations then change ahci to ATA.
SAVE &REBOOT
Posted on Aug 12, 2008
SOURCE: HP Workstation xw8200
Server 2008 is not detecting your drives, because it does not have drives for what ever hard drive controller you are using. You will need to determine which controller your drives are attached to and load the appropriate driver during setup. I believe this system has built in SCSI and SATA controller and often shipped with add - in storage cards. Our came with a promise sata raid controller.
Posted on Jul 22, 2009
  • 10406 Answers
SOURCE: I have an HP 513n, currently running Windows XP
Yes. Install the hard-drive, and use Windows XP to "partition" and "format" the second disk-drive.
When installing Windows 7, be sure to "point" the installer to the drive-letter of the second disk-drive.
Windows 7 will create a "dual-boot" environment.
Posted on Jan 29, 2010
WHY MI PC HP WORKSTATION XW6000 DO NOT TUR ON
Check first the power cable if it's properly plugged in, and if it's connected to a power bar, remove it from there and connect it directly to the power outlet
Jun 11, 2014 | Compaq HP Workstation xw6000 PC Desktop
Tip
Hp Workstation XW6000 Network Driver Download
After searching for about an hour for a driver for my HP xw6000, I took a shot in the dark and tried a Dell Driver. Guess what, it worked. Here is the link http://ftp.us.dell.com/network/R151327.exe. Hope this helped.
on Jul 22, 2011 | Compaq HP Workstation xw6000 PC Desktop
Change boot order bios
At startup, when it asks you about going to setup, hit the F2 key. The boot sequence is in there.
Aug 04, 2013 | HP Workstation Xw6000 PC Desktop
HP xw 4400 will not recognize my hard drive when trying to install OS Windows XP Prof.
Windows XP had a hard time recognizing hard drives larger than 127 GB. The best solution is to install Windows XP with service pack 2 or 3 already slipstreamed. Otherwise, you are going to have to partition your hard drive with at least 1 partition of 127 GB or smaller.
Dec 08, 2012 | HP xw4400 Workstation PC Desktop
Windows 7 not installing in Hp XW4100 workstation
Sounds like you need to format the hard drive then try a new install
Jun 21, 2012 | HP Workstation Xw4100 PC Desktop
New ram not working
Sounds like you bought the wrong kind of memory. It should be DDR PC2100 and it must be ECC (Not None Ecc).
Take a look at this site.
http://www.4allmemory.com/memory/compaq-hp-workstation-xw6000/
May 11, 2012 | Compaq HP Workstation xw6000 PC Desktop
I NEED WINDOWS RESCUE
if you have a second pc you can find a OS disc image by looking on google like typing windows xp home ISO download and when you download the image you will need a cd burner and a image program like IMG burn to burn the iso to a CDR
Dec 12, 2010 | Compaq HP Workstation xw6000 PC Desktop
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
HP Workstation Xw6000  PC Desktop Logo
158 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
