Question about Vivitar Video Cameras
Recharch vivitar 880hd dvr
Can't figure out how to charge or where to put batteries
ginko
  • 19396 Answers
SOURCE: vivitar 550 dvr camcorder will not charge
A charger kit can be purchased from the following link:
Click the link here to find the charger/battery kit.
Posted on Dec 01, 2008
SOURCE: Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Posted on Dec 20, 2008
SOURCE: How do you charge the Vivitar DVR 550
I just bought this camera used on Ebay and the seller told me it charges via the USB cable. He forgot to ship that to me, though, so I don't know yet if that is true or not.
Posted on Feb 23, 2009
girlwholost
  • 3 Answers
SOURCE: My DVR 500 camcorder won't charge. Any advice
check to see if theres any dust inside of the charging thing :D
Posted on Nov 09, 2009
  • 50 Answers
SOURCE: We have a Vivitar DVR 518 camera that will
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Posted on Apr 12, 2010
2001 chevy malibu wont charge my battery. I put a new alternator in and new battery lights on dash come on but the tachometer and speedometer along with fuel and temp gauge drop to nothing and the car...
Check the battery charging state yourself with a multimeter. Using the voltage setting, check across the battery terminals. WIth vehicle running the charge voltage should be around 14 volts. With ignition off the battery should retain around 12.6 volts or over.
If these are the figures you are getting close to then you have no charging issue or battery issue. You need to then check the on-board computers. You will need to run an OBD2 scanner and pull up any fault codes.
Nov 03, 2012 | Cars & Trucks
How long do you charge battery after you've done initial charge
a good rule of thumb is one hour for every amp hour that the battery is, so if its a 12ah battery then charge it for 12 hours
Jul 14, 2012 | Fisher Price Fisher Power wheels Cadillac...
Razor bella problems
Most likely a bad battery. Check out put voltage on all posts. If it's 12 Volts DC or more, then it should be ok, and you'll need to start looking in the wiring such as the speed control switch. If not, your problem is a bad battery cell and you should replace it. NEVER TRY TO SERVICE A BATTERY!!!!!
Jun 12, 2012 | Razor USA Razor Pocket Mod Electric...
After a year in storage, jeep won't work.
the radio runs off of a seperate battery source, so that wouldn't have any effect on this, i would first of all check the battery and charger with a multimeter and make sure that they are showing the correct voltage, if its a 12v battery make sure that they are showing at least 12 volts, if its a 6v battery make sure that its showing at least 6v
Jun 06, 2012 | Fisher Price Power Wheels Barbie Jeep
My razor dune buggy won't drive
are you sure that the charger is putting out enough volts to charge the batteries? check the charger with a multimeter, then check the batteries with a multimeter, and viually inspect the batteries for bulging
Apr 28, 2012 | Razor Dune Runner 350 Go Cart
2010 Elantra Touring - car won't start - doesn't turn over (battery is fully charged), clock/radio & A/C units don't work, and EPS doesn't work. Dealership cannot figure it out.
sounds like a fuse. check them and get back to me. If the shop you took it too cannot figure it out they probably should not be a shop. i hope they didnt get you for a diag fee. Im going to locate a wire diagram to help you figure this out.....Also you said you put a new battery in the car, check that the battery terminals are clean and tight.
Oct 06, 2011 | Cars & Trucks
Hello.I've got an Asus K52JE.Today I looked at the
97% isn't that bad, it means that your battery is fully charged but not the whole way. That is bound to happen specially when youre using youre battery a lot. It will get a lot more lesser in the future the more you use youre battery.
The standard laptop battery starts losing the ability to hold a charge after 300 recharges or cycles. If you drain your battery almost completely at least once a month and then recharge it, it will last longer & hold a full charge longer.
Jul 09, 2011 | ASUS Computers & Internet
I have a 2007 street bob took it out of basement charged battery and started right up.now bike wont even turn over battery had over 12 volts starter checked out alright replaced batteries in fob cant...
I can't figure out whether your problem is with the bike or the security system. I have no experience with security systems and don't have a clue. I'd take the battery out of the bike and take it somewhere to have it "load tested". Just because a battery shows 12 volts with a meter doesn't mean it's any good. Put a load on it (like the starter does) and you may find that it's a piece of junk. If it won't start then, I'd suspect the security system has it locked out. Sorry I can't help with that but I'm an old school biker and I don't mess with security systems.
Good Luck
Steve
Apr 13, 2011 | Harley Davidson FXDBI Street Bob...
Screen says battery is required to charge powering off
I was having the exact same problem and figured the battery or phone was hopeless because I've seen so many negative comments and no solutions. BUT, I kept messing with it and eventually I removed the battery and plugged the charger into the phone WHILE THE BATTERY WAS STILL OUT. Once I put the battery in with current already flowing, somehow, the phone started right up and started charging normally. Not sure if it'll work for every phone but somehow that did the trick for me and I've been messing around with my phone all day with no luck.
Jan 06, 2011 | LG RUMOR Cellular Phone
My air hogs switchblade's controler keeps turning off while its charging whats wrong?
always turn the switch blade off when charging it or it wont charge it and the red light goes off to save batteries on the controller..when done right it flashes red..only when it's flashing red and green will it be charged
Dec 31, 2010 | Master Heaters Air Hogs Switchblade Black...
Video Cameras Logo
422 people viewed this question
Top Vivitar Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
