Question about IBM 6400 Matrix Printer
P62 DC Pgm not valid
Hi, have an IBM6400 - will not print from AS400 now. Error on printer panel says P62 DC Pgm Not Valid.
Where can I find info on how to fix the error?
Thank you!
  • 3 Answers
Our IBM 6400 came with a bunch of manuals.
Do you have manuals on yours?
If you need to purchase or download manuals, here is one place you might start to figure out what they cost & where to get what you need.
http://publib.boulder.ibm.com/infocenter/printer/v1r1/index.jsp?topic=/com.ibm.printers.printerinformation/ic5g2mst159.htm
Posted on Nov 12, 2008
Ibm 6400-008 with P62 error
P-62 error is DC program not valid. The printer cannot find the controller program or the validation checksum is corrupt.
You can try to reseat the flash (memory simms) but it probably will not help. You need to re-download the program (microcode) to the machine and if it still fails replace the flash with pre-writen flash.
If you need a copy of the microcode and instructions on how to load let me know here (I will try to keep an eye on this post)
Dec 30, 2009 | IBM Infoprint 1332 Laser Printer
How do I program my Uniden BC72XLT race scanner?
1. Press HOLD. Then enter the channel number
where you want to store a frequency, then press
FUNC and PGM. The channel number appears.
2. Use the number keys and to enter the
frequency (including the decimal point) you want
to store.
3. Press E to store the frequency into the channel.
Notes:
• If you entered an invalid frequency in Step 2,
ERROR appears and the scanner beeps three
times. Enter a valid frequency.
• The scanner automatically rounds the entered
number to the nearest valid frequency.
For example, if you enter 151.473 (MHz), your
scanner accepts it as 151.475.
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Nov 02, 2009 | Uniden BC72XLT Handheld Scanner
DC PROGRAM NOT VALID
Usually with this error the program checksum for the printer controller is corrupt or the data controller memory is corrupted.
You can try redownloading the program into the printer or it's possible it also has bad Flash Memory.
Jul 15, 2009 | Printronix Line Matrix P5005B Printer
P62 error dc program not valid
Did you try reflashing this unit and then it came up with this error? If not you might need a reflash or a new CMX controller bd.
If you have any other question please contact me I am an ASR for Printronix and they built the 6400's for IBM so I know the pritner inside and out. I also carry all the parts new and refurbished to fix it.
Please let me know.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 09, 2009 | IBM 6400 Model 010 Matrix Printer
Xerox 7232 and As400
016-799 is a printer paper conflict error. All you have to do for the AS/400 to print, is to make suree that tray 2 in the printer is set up to do landscape printing. There has to be at least one tray for portrait, and one for landscape in order for the AS/400 to print.
Mar 20, 2009 | Xerox Office Equipment & Supplies
P62 error code
The IBM 6400 printer uses internal programming software that is specific to the printer based on installed interfaces and graphics options. This software resides in flash memory and when the printer is first powered on the software is executed. During this process it initializes the various processors on the controller board, initializes the optional interface cards, and then loads the necessary operating settings into dram. If the programming software becomes corrupt it will fail during startup, giving you the DC Program not valid error or a number of other error messages. The solution to this is a reflash of the printer. Unfortunately, the flash software is proprietary to IBM and they will not distribute it to anybody. The only way to get the printer reflashed is by calling IBM and having one of their engineers reflash the printer.
Jan 28, 2009 | IBM 6400 Matrix Printer
HP Photosmart D7460 Error Message
Using an administrator account, remove HP Smart Web Printing using Control Panel - Add/Remove Programs.
If required, download and install HP Smart Web Printing from http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&softwareitem=dj-56929-4&os=228&product=3551212&
(Thanks to Bellbird at http://forums.pcworld.co.nz/archive/index.php/t-91677.html).
Nov 09, 2008 | HP Photosmart C7180 All-In-One InkJet...
My Printer want stop printing!!!!!!!!!
try to check the queue for pending document and cancel it if you find some. to do it:
control panel > printers & faxes(xp)printers(vista) > double click cx7400 icon - this is where you can check if there are pending docs. to dlete: on the same box click printers and select cancel all documents.
regarding enter valid product, where did you get the error from?
May 05, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printronix p5010 with AS/400 IBM server
I can get the P5010 printing on your AS400... But, there are to many things to check without knowing a little more about your environment.
If you can't ping the PTX P5010 from the AS400 or a PC, then you have a printer configuration problem.
Take the printer offline and hit the Print Config button. and then the enter on OPs Panel. Then post top or first paragraph of the config. so I can look at...
__________________________________________________________
If you can ping the printer from the AS400...
You will need to create a remote out que on AS400... command is crtoutq then hit F4...
if you can't post the printer config here... Fax it 972-233-7306, Attn: P5010, Toby
Dec 12, 2006 | Printronix Line Matrix P5010 Printer
IBM 6400 Matrix Printer Logo
755 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
