Question about GE Refrigerators
I need a manual for GE side by side model GSS25WSTA SS
Moved refridgerator and now front control panel will not come on.
SOURCE: GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Posted on Jul 30, 2008
docjohn174
  • 943 Answers
SOURCE: GE Profile PSS26NG Not cold
hi thanks for the question the problem you are having is with the defrost cycle . check the defrost timer and the defrost termination switch. and also clean all coils at the back, and clean drain tube ,from freezer to drain tray at the back. thanks the appliance doc. rate me please
Posted on Oct 01, 2008
  • 35 Answers
SOURCE: GE gss25sgrb ss Fridge temperature control keps resetting
THAT IS YOUR DAMPER CONTROL AND IT WILL NEED RERPLACED
Posted on Jun 18, 2009
aasc
  • 1606 Answers
SOURCE: we have a gsh25jftfww ge fridge. the temperature
Your refrig uses a main control board that is on a recall list .The board uses a WR55X10552 . The replacement board is WR55X10656 . I would suggest calling GE factory service and they will cover this under warrenty , due to the recall .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Posted on Nov 01, 2009
  • 207 Answers
SOURCE: GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Posted on Feb 24, 2010
I'm looking for a manual for a GE SxS Model G8622BLCC. All I need is to find out where the temperature control knobs are located for the freezer and fridge?
They're probably in the refridgerator compartment near the top either toward the front or back of the compartment.
Oct 05, 2014 | GE Refrigerators
The house we moved into has a GE select side by side refridgerator with a water dispenser. I was wondering if it had a water filtration system and if not, is there a way to add one?
Most refridgerator filters on older machines are located externally. Without Model # it hard to say but I would look behind the machine for a cylinder about 10"-12" long and 3" in diameter. It would have a small either copper or plastic tube attached at both ends.
Jan 06, 2011 | GE Refrigerators
My ice maker on the freezer side door stopped working so I changed out the motherboard CCA in the back of the refridgerator & it started working again but the water did not. I need to replace the...
Blake are you talking about the dispenser control board? The ice maker tells the water control valve to come on for the preset amout of time to refill the ice trays most times about 7.5 seconds. and filling ice maker with tap water will test icemaker. If water freezes and the ice dumps the signal is sent to the water control valve Click here=> WR57X10050 here is a service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE Have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator & freezer not cooling much, ice crystals on inside of freezer
Need you to unplug and remove the back panel in freezer to examine the evaporator coil. Check the defrost element and the defrost thermostat. On the back of the refrigerator is a main control board located behind a panel screwed to the refrigerator back. With the power off through all of this I need you to inspect the control board for burn marks on both sides. Click on link below and enter your model or 1 of 34 models like yours. Place model GSH25JFR in model parts search this will lead you to the many similar models like yours. On diagrams on left of your screen count eight down that shows the circuit board. If no burn marks I will tell you how to test the other parts I mentioned,
Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Ref #ESS25LSRCE SS
are you sure it is not a GSS or a PSS model i have the manual on that post your email and i will send it to you
Mar 10, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE PFSS6PKWSS refridgerator side panel
not gonna find another manufactures product to match your dimensions, best bet is to find a local metal fabricator get a s/s panel cut to the dimension you need, silcone or a quaity double stick tape will secure it to where it needs to be
Mar 05, 2008 | GE PFSS6PKSS
GE Arctica Refridgerator, PSS26MSRB SS, water leaking from tray, and other questions
ok first the water dispenser i would take out the drip tray and run a thin bead of black silicone to seal it there as to the turbo light getting brighter its because when you switch on turbo its running more power through the switch to the fan now to the fan early model fans were noisy i think ge redid them and if you contact ge you can get one of the newer fans hope this helps by the way loved the pics and mpeg that helps
Jan 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
244 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
