Question about Samsung Digimax L730 Digital Camera
Camera wont turn on
My camera has an issue. It was connected to the computer (charging I suppose). I pushed the power button to turn her on but when I pushed it the blue light on the button and the green on for about two secons and then it turns off. I let it on the computer and I also used the regular adapter on an AC plug for about an hour each. ALso I tried removing battery + memory card for an hour but still nothing that could help. If anybody has any ideas on what is going on I would really appreciate it. Thank you.
  • Anonymous Oct 30, 2008
    I plug in my camera to be recharged the lil light up triangle on the attachment cord lights red them green then orange????? & refuses to charge i can't turn the camera on as the battery is completely dead, is it the lead or a problem with the connection?????
I've got the same problem please let me know if you figure out what the problem is, i'll do the same if i firgure it out, i feel lost without my camera
Posted on Oct 30, 2008
Wont turn off-on
Taking out the battery, when a camera acts strange, is a good thing ONLY. be sure the camera is not busy saving pictures, because you could damage all pictures on the memory card.
I'm not sure the lens was out, when it was connected to the computer. Let us assume it was. Normally, the battery should be charged when the camera is connected to a USB connector on the PC. But not all USB connectors are perfect wired. And if you use a USB hub you can be sure the battery was not loaded. So as soon as the camera came from the PC it needed full power and could not get it.
Now you removed the battery, but before placing it back in the camera, please charge it on an external charger. When you place the charged battery, and the yellow light starts flashing again and won't stop quick, you could try to reconnect the camera to the computer and see what that brings. I would have switched off the camera, before I disconnected it from my PC.
Than the sand issue. If just a grain of sand is in the lens bellow, it could serious obstruct the lens from going back. If you can see the grain of sand, you could try to get it out. Very thin needle (or two?)
But if you can't see something, don't move the lens at all.
You could damage the gears in the focus and zoom mechanism.
I wish you luck with the camera.
Nov 11, 2013 | Samsung Digimax EX1/TL500 Digital Camera
My HDV527W camera only says usb connected and it never charges
Have you loaded the driver program for the camera ?
Also the camera should be switched on when connecting to the PC.
Feb 20, 2012 | Cameras
Flip Mino HD red light won't turn off after charging. Camera won't do anything at all. What do I do?
return it for a refund! i bought one, it did the same as yours. i returned it and bought the 2nd one. It did the same as the first one (and the same as yours.)
It is a piece of junk. Supposedly the previous Flips were good, unfortunately, I didn't have the previous models so my experiences only are bad.
Aug 09, 2010 | Pure Digital Flip Video Ultra Camcorder
My camera wont turn on but says connecting computer why
If the USB cable is not plugged into the camera, turn it off and take out the batteries. Push the power button a couple of times with the batteries out. Put the batteries back in and try to turn it on then.
Jul 19, 2010 | Samsung Digimax D53 Digital Camera
My sony digital cam wont turn on or remain on. please help me. tell me what i should do
  1. Ensure you are using fresh or fully charged batteries. IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
  2. Attempt to turn on the camera.
  3. If the issue is not resolved, try replacing or recharging the batteries if available.
  4. Attempt to turn on the camera in Playback/Edit mode by moving the mode switch to the Playback/Edit mode or by pressing the playback button.
  5. Switch the unit to camera mode and attempt to turn on the camera.
  6. If the issue is not resolved, try connecting the AC power adapter to the camera and a working electrical outlet. NOTE: Skip this step if the camera being used does not support the use of an A/C adaptor.
  7. Attempt to turn on the camera.
  8. Remove the Battery, press the power button for 30 seconds.
  9. Please wait for one minute, insert the Battery and turn it on.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. [[]]
Jun 25, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Dsc p73 wont switch on when in green camera mode. Tone is short, swiches on in photo preview only with normal tone battery is fully charged.
I'm sorry that the camera is not turning ON. Please make sure that the battery is fully charged.
Please reset the camera by pressing the reset button located near the DC IN jack. if the issue still persists, please power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 26, 2009 | Sony Cameras
My Kodak Easyshare M7623 Digital camera will not come on. It is completely charged and the lens is out. When i push the ON/OFF button the screen comes on and quickly goes of. The lens remains out the...
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 20, 2009 | Kodak EASYSHARE M763 Digital Camera
Kodak EasyShare C613 turns off when connected to PC
The camera is supposed to go blank when connected to computer.
I hit the "share" button and can then download photos, even though screen is still blank.
Feb 25, 2009 | Kodak EasyShare C613 Digital Camera
Samsung Digimax L730 Digital Camera Logo
46 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
