Question about Microsoft Windows XP Media Center Edition 2005 for PC
WINDOWS XP MEDIA CENTER
MY COMPUTER WILL ONLY BOOT WITH A SYSTEM DISK IN 3.5" DRIVE AND SAYS I HAVE A FLOPPY DISKETTE SEEK FAILURE. COMPUTER WILL NOT RECOGNIZE ANY OF THE DRIVES. IE CD:\C DOES NOT BRING UP THE HARD DRIVE.ANY HELP IS APPRECIATED.
  • 76 Answers
Try going into the bios and changeing the boot device to hard drive. More iformation is needed though to help you ie os version, what you done just before this problem had arisen , brand name of your computer. let me know im sure i can assist you and try not to get frustrated these things happen more often than you know.
Posted on Oct 27, 2008
My dell c521 says diskette drive 0 seek failure
You need to press f2 then go to Standard CMOS Features, then highlight drive A. Change it to none. You should not have anything in there enless you have floppy drive
Jan 14, 2014 | Dell Dimension C521 PC Desktop
Floppy diskette seek failure
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
Boot up problem with Dell Precision 380 P4 Dual Core 3 GHz
Your computer is trying to boot from a floppy drive. Do you even have one? If not, then you need to go into the BIOS (set-up) menu and disable it. Be careful though, you could loose all your data on the computer if you make a wrong selection. As for an array message, you must have have a RAID disk configuration. That means you have 2 or more disk drives that mirror each other.
Mar 17, 2013 | Dell Precision 380 P4 Dual Core 3 GHz...
My dell dimension 9200 is booting and then giving me a Floppy Diskette Seek Failure message. What is causing this to appear and not boot windows 7?
Hi. You computer seems to be booting up using the floppy disk and your floppy disk drive might not be connected properly, not working or not even there. Press F2 to run the setup utility and disable the floppy seek in the bios. It will most likely be in the "Advanced CMOS setup" area, or the 2nd screen depending on your bios. look for "Seek floppy drive at boot?" or, "Disable floppy seek at boot?" or something like that. When you find it, make sure it's not enabled for the seek. Save the change on exiting. :-)
Jun 05, 2011 | Dell Dimension 9200 PC Desktop
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Black screen with Diskette drive 0 seek failure on it. pressf1 to continue, f2 to enter setup
diskette drive o or disk drive o? f2 to enter bios check boot options to boot on drive o [hdd-0], most boot options go floppy,cd-rom, hdd-0
Feb 04, 2010 | Dell Inspiron 530s Desktop Computer
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
Jan 14, 2008 | Dell Dimension 4600 PC Desktop
Microsoft Windows XP Media Center Edition 2005 for PC Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
