Question about Goodman Heating & Cooling
Goodman urnace 6 flashes ,Rollout & possibly open fuse
5 Suggested Answers
  • 15 Answers
SOURCE: My furnace, a goodman gmh951155dxa is not running
did the tech check the heat exchangers
Posted on Jan 02, 2010
SOURCE: I get a flashing light
I will advice you replace the fuse on your heater and see if it will produce heat.
Posted on Oct 04, 2010
  • 3074 Answers
SOURCE: goodman model pgb030075-1 unit has led flashing on
maybe the exhaust fan is not getting power, here is a website that should help, Tim:
http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
Posted on Nov 12, 2010
  • 1033 Answers
SOURCE: I have a Goodman GMH95/GCH9 furnace. The blower
Hello, you can check the resistance of the motor by turning power off to the furnace and disconneting tje two wires which go to the motor. Take a meter and check the resistance, you should have resistance, if not the motor is bad. A rollout switch is a normally closed switch so you will chevk its resistance aswell, if the switch is open that signals a problem with the burner flames and you not read resistance. If the switch is closed and good you will read resistance.
Posted on May 01, 2011
Testimonial: "very helpful and fast response"
Got goodman gms91155dxa got 6 flashs says rollout open
Check the roll out switch it is located right in front of the burner assembly it will have two wires on it some times they are resat-able if you have to reset it do so and then put on the heat to see if flames are coming back out to trip the roll out sensor. make sure the heat exchange and burners are clean.
Feb 16, 2015 | Goodman Heating & Cooling
Why condenser won't start board flashes6times meaning open rollout
check your roll out with an ohm meter they should have continuity if not they have a reset button on top of the switch push it and this will reset them. If they don't have continuity they are open.
Jul 17, 2014 | Goodman Manufacturing Goodman DSXC180601...
Open rollout or open fuse on Goodman
the fuse is located in the circuit board in the blower compartment and the roll-out is located in the burner section and can be a reset-able switch style or the one time fuse link style which is a a small silver cylinder and is mounted in a ceramic piece and is held in with one screw. Both of these are mounted around the opening of the your burner assembly near the opening. This will be near the area of the gas valve.
Sep 24, 2012 | Goodman Manufacturing Goodman R410A 13...
We r in our NEW house built in 2008. HVAC unit looks clean, & New. our A/C do not work, or kick on. the unit is Goodman during troubleshoot found-open rollout ->6 flashes gmh80704bn -...
If you didn't reset the rollout switch, the air will not work. The rollout switches are in the furnace burner secton. Look at the burners, the rollout switch(es) are just above the burner. They will have a button on top to push for reset. These rollout switches will generally have two wires going to them.
May 18, 2011 | Heating & Cooling
I have a Goodman GMH95/GCH9 furnace. The blower runs but no flame. LED is on (normal operation) checked fuse ok. held down fault button-6 flashes. didnt look like the draft blower turned on when a call for...
May 01, 2011 | Goodman Heating & Cooling
My furnace turns off and I am getting an alarm OPEN ROLLOUT. I reset it and work for 6 hrs, 3 hrs and last time worked 2 days straight.What could be the problem
Hello, a rollout switch opens for several reason, a damaged heat exchanger,lack of combustion air, impoper gas input. I would have a technician come out and check these three things.
Feb 26, 2011 | Goodman GMS90703BXA Heater
What is code flashing 6 times mean?
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Sorry to read about your problem, I hope this helps you out.
Circulator blower runs continuously. No furnace operation. Integrated control module diagnostic LED is flashing SIX (6) flashes.
6 FLASHES
1 Rollout limit circuit is open.
2 Flame rollout. i? Misaligned burners, blocked
flue and/or air inlet pipe, or failed induced draft blower.
3 Loose or improperly connected wiring.
4 Check burners for proper alignment.
5 Check flue and air inlet piping for blockage, proper length, elbows, and termination. Correct as necessary.
6 Check induced draft blower for proper performance. Replace, if necessary.
7 Tighten or correct wiring connection.
Turn power OFF prior to repair.
i? See i?Vent/Flue Pipei? section for piping details.
i? Ensure the correct pressure switch replacement is used.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
Dec 29, 2010 | Goodman GMS90703BXA Heater
Goodman model pgb030075-1 unit has led flashing on circuit board (1 flash) replaced open rollout switch unit heated for one cycle,won't refire makes three attempts then locks out
Nov 12, 2010 | Goodman Heating & Cooling
Goodman down draft Gas furnace, red led flashes 6 times meaning on the list, A "Rolling Open" The forced air blower turns on, the burner fan turns on, No Glow plugs turn on at the burner box to ignit the...
Hello Try looking for a tiny TAN colored (button) near the front of the burner rack.It will have a wire in & out of it.In the middle there is a small tab/button.Push that in you will hear a click.That is the rollout switch.Check the vent/exaust pipe for blockage/draft to determine the cause of the switch tripping.The switch is a SAFTEY and repeated trips means there is a problem.
Sep 08, 2010 | Goodman Heating & Cooling
Heating & Cooling Logo
203 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
