Question about Rheem Water Heaters
I am getting hotwater downstairs but not upstairs, what could the problelm be?
I get hot water downstairs but not upstairs, not sure what the problem could be. I have got the dial turned up full and still nothing...it is luke warm water
kma836
  • 7 Answers
SOURCE: boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Posted on Oct 18, 2008
  • 17 Answers
SOURCE: boiler shuts down repeatidly
i think you will find that instead of modulating as demand requires the boiler is overheating and then re operating after the safety thermostat has operated.
i wilud put some de scaler into the main heat exchanger circuit or add it to the radiators and let it circulate for a while.
also make sure the pump is operating properly to ensure proper water flow.
Posted on Nov 29, 2008
co7196
  • 3433 Answers
SOURCE: Intermitent heat from Atwood 10 gal marine water heater
Water level safety shutting down heat source
Posted on May 24, 2009
  • 21 Answers
SOURCE: no water coming from my hot water taps, upstairs
Is there any water at all coming out? If not turn the cold water tap on the hot water tank on.
Posted on Nov 27, 2009
motor1258
  • 6674 Answers
SOURCE: extreme hot water then to consistent luke warm
Possible thermostat problem. Are you experienced enough in that area to do some testing. Have a multimeter? If not experienced, don't try it, too dangerous. Call in a service person.
Posted on Mar 07, 2010
I have a Vaillant Combi boiler, recently serviced by British Gas, given all clear. Problem we are having is the downstairs hot water tap it is a mixer tap, the cold water is fine but the hot water is
Boilers are inherently dangerous for the average DIY for so many reasons, contact British Gas and have them come back and fix it, tell them it was fine before the "service". They may simply have a control valve shut off.
Sep 23, 2014 | Water Heaters
How can I increase the hot water pressure in my home?
Cold water pressure is what give you your hot water pressure so they should be equal but if you have a restriction on the hot side such as a valve not opening on the hot side or not opening all the way then you will have less pressure or the pipe work on the hot side is not proper. Hard to say but check the valve on top of the hot water heater
Aug 13, 2014 | Water Heaters
My water heater heats everything except my lower shower
Let's walk our way thru this one: I assume you have an upstairs shower, and a downstairs shower?-- Are you able to follow the pipes coming out of the Hot Water Heater?-- Can you trace where the pipes to the upstairs shower go?-- And what about the pipes to the lower shower? -- Do they BOTH come off the HOT water pipes coming out of the top of the HW Heater?
A big help in tracing pipes, is by having the hot water run in the Shower that is getting HOT water-- Feel the HOT! pipe?-- Now-- shut that water off, and go to the lower shower-- When it is running, can you hear water flowing out of the pipes at the top of the Hot Water Tanks?-- or do you feel Cold water moving-- Can you travels where it is flowing from? Get back with me, and tell me what you are feeling, and hearing-- Mack B
Oct 15, 2013 | A.O. Smith Ao Smith Bt-80 Conservationist...
I have an instant hotwater system with the futher most bathroom about 45' away. I am looking at adding a recirculating pump on a timer at the furthermost bathroom to get hotwater quickly in the...
Maybe I am not understanding your problem exactly, but if you have the instant hotwater system installed it should be measuring the temperature of the water in the hot water line and if it drops below the set level it should open the hot water side until the temperature is reached. If it was installed correctly it puts the hot water back into the cold water line so it isn't wasted.
Sep 18, 2011 | Grundfos RCP-96 Recirculation Pump for...
Had three 50-gal American Standard water heaters installed Dec. 2009 Two upstairs in attic, one downstairs at ground level. Attic location used because heaters being replaced were up there. Upstairs...
Plumber is right.
Problem is not amount of air in attic. Problem is how hot the air is.
Oxygen molecules separate apart in very hot air and pilot light goes out since there is not enough oxygen density to support combustion.
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
More ventilation is needed.
Plumber is not ventilating expert, and not responsible for attic ventilation that builder failed to install. Plumber should do a survey of location before installation to make sure gasoline vapors are not stored nearby, but summer attic ventilation is gray area until more general-public folks become aware of problem. Hotter summers temperatures will spread that information.
Hire local home center to install roof vents AND soffit vents.
Note: You also need soffit vents.
Remember a vent on the roof is like sucking air out of a coke bottle. The roof vent is no good unless air can also enter the attic from another vent located in the soffit.
Another solution is electric water heater for very hot locations.
Or install solar-assisted water heater.
http://www.hotwater.com/products/residential/cirrex_solar.html
Jul 28, 2011 | American Standard 40 G Natural Gas Water...
We had no heat in rads downstairs we changed pump and flushed system no we have heat downstairs but not up any ideas?
Make sure the air is bled from the upstairs rads.
[air = top of rad is cold & bottom hot]
If you need to balance the rads to maintain an even flow through all then :-
Turn off all rads [one valve fully open and the other closed] Get heat going and open each rad valve, in turn, about 1 or 2 turns. Start with upstairs. The position you need to get to is when the return pipe fron each rad is a few degrees below the flow pipe. Adjust each rad valve to get this effect a few times may be necessary
Mar 19, 2010 | Water Heaters
No water coming from my hot water taps, upstairs or downstair.
Nov 11, 2009 | Emerson Water Heaters
Central heating circulating pump
The vent pipe should be in front of the pump so that the pump pushes towards the vent pipe NOT sucks from it. I hope this vent pipe is part of the heating system and not of the hot water
Pumps like to push not pull and therefore it is better if the pump is located further down - say at the bottom of the cylinder or lower.
With an indirect cylinder, the hot water & heating are separate circuits and are not and must not be interconnected. You will need a separate pump for the hot water which should be taken from the hot pipe coming out of the cylinder. You may get vacuation in the cylinder - then you will need an Essex or similar valve to replace the hot water outlet connection
By the way - The pressure at any hot tap is directly related to the height difference between the tap and the header tank in the loft [thus a shower downstairs feels stronger than one upstairs]
rod_davies@hotmail.com
Sep 03, 2009 | Grundfos RCP-96 Recirculation Pump for...
Water Heaters Logo
195 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
