Back to:
Tags:
JVC KD-AVX1 Car DVD Player
Nothing works (by 6 users)
posted by smays13 on Aug 29, 2006
I some how shorted out my receiver. The only thing it will do is eject the disk. I have tried reseting the unit, and the lights around the buttons come on for a few seconds. Does anyone know what is wrong and how to fix it?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Guest, posted on May 09, 2008
I have the same problem, have tried everything and it doesn't work. I knwo there's power going to the unit, because it will eject CD's nothing else though.
Comment by alidani, posted on Apr 16, 2008
i get sound but the screen stays black. Is there a fuse for the screen?
Comment by Guest, posted on Apr 16, 2008
I have sound but my screen stays black. Is there a fuse?
Comment by saxmo, posted on Feb 17, 2008
the disk ejects but that is all it does. is it my fuse if so where do I find it dodge durango 2005
Comment by ewms, posted on Jan 03, 2008
How do I check the fuses in the unit?  My unit stays on for a few seconds with the lights, then clicks off also...
Best Solution
posted on Aug 29, 2006
Thanks for Trying (70)
The Marv
Rank:Wiz Wiz
Rating: 84%, 257 votes
If this unit uses a switched power wire and a memory back up. usually onewire is red and the other wire is yellow. off of the head unit. but the car wiring uses two fuses for these wires. A lot of times thet will be mixed in with dash light dome light, or something like that. But there will also be a Radio fuse. But if one wire is not getting power it can case the unit to malfuction. I do not know what kind of car you drive. But different cars put fuses all over the place from under the dash to under the hood. Also be sure to check fuses on the unit itself.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Nothing works:
I don't want to Accept this solution
Solution #2
posted on Aug 10, 2008
Not Rated (0)
gutembergues
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
maybe your just using the red (positive) whenyou should be using both red and yellow worked for me
Thank You!
Solution #3
posted on Mar 24, 2007
Not Rated (0)
br3341
Rating: 82%, 17 votes
my friend had the same problem his acc wire (red) shorted out and burnt some where in his car. So we just ran another wire to the radio and spliced it in with the acc wire.
it still works so we don't Know how it shorted out
Thank You!
Solution #4
posted on Dec 27, 2006
Not Rated (0)
ampman
Rank:Wiz Wiz
Rating: 84%, 72 votes
ampman indicated that his solution for
VRX755VD Car DVD... Problem
is valid for all JVC Car Video...
get yourself a test light. they ar eonly a few bucks. check power on the yelow wire of your deck and the red wire of your deck. both shoudl have power with the key on... if you hav epower to both of those and the deck still doesent work then its dead. I buy dead clarions for parts to if you give up let me know.
mike bigmikeselectronic@comcast.net
Thank You!
Can you Help with these Car Video Players problems?
my kenwood ddx7017 music system is not working properly....
When I put in the dvd it says reading disc for a while,...
Just installed amp and bass speaker, cannot get any signal...
it says reset the p23 code what is that and when you open...
my dvd dont read zone 2 what i can do ??
Loading problems.
Repair Service
Find Car Video Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
