Question about Cyberhome CH-DVD 300 DVD Player
CYBERHOME DVD PLAYER VIDEO MP3
DVD DISC IN TRAY AND TRAY WON'T OPEN WHERE I CAN REMOVE DISC. CAN YOU HELP ME?????
  • shellimoore Nov 12, 2008
    DVD will not open.
  • Anonymous Nov 15, 2008
    i can't get it to play or give the disk back. the green light won't even turn on. the thing doesn't belong to me so i can't take it apart! X(
  • 3 Answers
Take the top of it off and then take the disk thing that holds the disk on the thing that spins it off and remove the disk.
Posted on Nov 01, 2008
Can the DVD player be played while on it side.
Yes it will play on it's side after the disc has been clamped in the player. If the disc tray is not designed to be upright then the disc will fall out when you open the tray
Sep 09, 2014 | Cyberhome Televison & Video
I inherited a dvd player from a family friend when he died but he no longer had the book for me to code it as it is not a multi region dvd.
Could you please give me the brand and model of your unit so I can further assist you. Thank you.
Feb 05, 2008 | Televison & Video
Door won;t open
I have a yellow light .on the front, and the disc tray won't
open. I have a cyberhome DVD player,CH-DVD 300.
Oct 28, 2012 | Cyberhome CH-DVD 300 DVD Player
My disc tray won't open the lights turn on and work but the disc tray just won't open. How can I fix this?
hi,
You have to check two things.
1. You have to check the tray loading belt in the mechanism. To see the same you should remove the mechanism.because the loading belt is beneath the cd tray. As it is cyberhome it will be very difficult to remove the mechanism for an user. if your capable for doing the same then make try. Because you have to remove the top cover then the back panel, then the mechanism. Take care the mother board is attached to the mechanism.
2. You have to check the cyberhome dvd player will show this type of complaint if the Spindle motor is faulty (oppen or short ). Spindle motor is one on which the cd rotates. It will not cost a lot.
ok
May 05, 2011 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 not stuck on main blue Cyberhome screen
It may not be able to read the DVD because the laser is dirty. First try to reset the system ( with no disc inserted, open then close the disc tray and hold the stop switch on the UNIT NOT THE REMOTE for six seconds). Then with the disc tray open using a can of "AIR DUSTER" - dry air in an aerosol can, insert the can nozzle into the disc tray cavity and spray away. That may blow off any dust on your laser eye. Try it again and if it still wont work,unplug the unit and remove the six small Philips screws that hold the cover on( it pivots up and off from under a lip in the front panel), plug it back in and open the disc tray exposing the laser and clean the lenses with Isopropyl alcohol and a q-tip. Do this GENTLY you don;t want to disturb the laser alignment. Dry with another Q-tip or the Airduster and re-assemble. Note well the unit will be POWERED with the cover off so BE CAREFUL. Just did this with mine and it now works like a charm again.
Dec 05, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome dvd player ch-dvd 300 What region code is this dvd player? can it play region 2 dvd's?
Dear friend,
Try this method to change the region.
1. Switch player on, making sure that there's no disc in the tray.
2. Close tray.
3. Using the remote control, key in the following: MENU, 1, 9.
4. A menu will appear with the region option near the bottom of the screen.
5. Press ENTER, enter the desired region AND PRESS ENTER again to save the desired region.
6. Next press OPEN / CLOSE.
Nov 18, 2008 | Cyberhome Televison & Video
Changed Video Output Setting
Reset you player by doing the following:
With the player on, hooked properly to your television1.gif, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 27, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD stopped playing all DVDs
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome DVD 300 Video player
On the bottom of mine there is a tray release switch.....
Dec 30, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
65 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
