Question about Sharp R-1870 Convection/Microwave Oven
Sharp microwave model #1872
The microwave will still turn on and you can still hear the fan blowing. The turn table no longer turns and will not heat on either the microwave or the convection setting?
  • carolyn10 Nov 01, 2008
    You hit the nail on the head! I had never tried your website before, so unfortunately I didn't wait for your response before I called a repair man. Boy did I learn my lesson. I spent $120.00 and felt like I got a fairly good deal. (After all I didn't have to buy a new microwave.) I will totally trust this site and come here FIRST each and every time! Thank you for your timely response and for teaching me a valuable lesson!
Small clear square at top of oven missing
Posted on Dec 02, 2008
  • 100 Answers
Most likely the lower door interlock switch is bad. Cheap and pretty easy repair.
Martin Microwave Inc. sells the switches for around $5....
www.martinmicrowave.com
Posted on Oct 31, 2008
SHARP microwave Model no R-957(W)M.Its working well but problem is on any mode, it stops after 59 seconds even if I set it for a minuits or 2 minuits. Please show me the solution. Thank you very much
Timer section is fubar. Reset the electronics to factory defaults and see if that cures the issue. If not, the timer section needs to be replaced.
Sep 22, 2017 | Sharp Microwave Ovens
How to fix loud hum and no heating in Sharp model R-308KW?
There could be a variety of reasons why this happens, but the likeliest
reason is the secondary interlock or monitor switch is broken. These are micro switches that tell the microwave that the door is closed. If this switch is broken, then the microwave thinks the door is still open and the carousel table won't turn, and the oven will not heat up.
I replaced an interlock switch last Saturday. The switch was $7.00 and took me an hour.
Ask your local repair person to test the interlock and monitor switches first, then go from there.
Good luck,
Hank
Jul 09, 2014 | Sharp R-308KK / R-308KW 1100 Watts...
Model MH6141XKQ-1- won't heat- blows air from the top vent and plate does not go around
microwave model mh6141xkb=1 fan and light go on,but turn table will not turn or heat up.
Jan 15, 2011 | Whirlpool Microwave Ovens
Whirlpool model number MH7140XFB no longer heats
you either need a new h.v. capacitor or h.v. diode in the magnetron circuitry if you cant hear it cycle when it runs as in a low pitched hummmm when its drawing current to operate the magnetron tube, each part runs about $30 to $45 each,normally its the h.v. capacitor though
Jul 28, 2010 | Whirlpool MH7140XF Microwave Oven
My sharp R-340H no longer cooks. Still powers up
Please check the door safety interlock switches ...
If the switches are faulty, the oven thinks the door is open and will not turn on the heat ...
Find them indice hear the latch assembly.
Jul 09, 2010 | Sharp R-340 Microwave Oven
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
When you press start I can hear the internal fan, but the inside table does not turn and there is no cooking taking place. What should I check first and what could be the problem?
This looks that the motor is not being functional, for that you have to look for the fuse if one. or else check the circuit if any wire is disconnected or burnt out accordingly you can decide what needs to be done.
May 05, 2009 | Sharp R-1874 Convection/Microwave Oven
Microwave will not heat any thing.
the plate has nothing to do with the microwave heating up the food
but the magnetron that heat the food is bad and will need replacing
I would ask a electronic shop how much they would charge to replace it , and if is not worth it to you then a new one would be a good call
Dec 01, 2008 | GE Microwave Ovens
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Sharp R-1870 Convection/Microwave Oven Logo
132 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
