Does anyone know why the buttons on my Xerox XA17i monitor might not be working please.
SOURCE: Xerox WorkCentre XL2120 Vista Compatable Driver
Here is the answer from Xerox
Windows Vista Note: There are no plans to develop Vista drivers for the Xerox Small Office/Home Office products. Please check with a Xerox Sales Representative for the latest products with Vista support.
SOURCE: my xerox lcd monitor is not working the power button is not lighting up
Computer Post / Beep codes
The computer POST (Power On Self Test) tests the computer, insuring that it meets the necessary system requirements and that all hardware is working
POST troubleshooting steps.
then this issue is not a NO POST but is an power related issue see document ... For users who are more comfortable working with the inside of their computer.
Good Luck, Please dont for get to Vote/Thank You.
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
SOURCE: Faulty Monitor?
I had the same problem, dead p.o.s. I enjoy this monitor, it’s one of the few on the market that are completely flat on the face. Great look! I own two, one used off ebay, repaired. Land fill, no fukin way. Found a fellow who can fix the power supply on ebay, $40.00 . I found a fix here on Fixya. Went to radio shack, better to order on line their inventory for these parts is itty *****, the same size capacitors, only $10.00. Inside in the guts of the power supply the capacitors were bulging and leaking.
Pulled them out and amateur soldering popped in the new ones, replaced 4 of the 6 big fukerz. Harest thing was getting the cover off, slight pry and slide up. And whalla! Good as new. Got 5 years on this one XG-91. Suk me Xerox for cheep o Partz! Burn the fuckerz that don’t make things to last!
