Question about Biostar K8M800-M7A Motherboard
POWER TO MOTHERBOARD NO BEEPS AND WON'T BOOT NO SIGNAL ON SCREEN
LOOKING ONLINE, COMPUTER FREEZED SO I SWITCHED IT OFF BY UNPLUGGING IT, WHEN I SWITCHED IT BACK ON IT POWERS UP THE MOTHERBOARD, THE FANS START, THE DISK DRIVES OPENS BUT NO BEEPS AND NO IMAGE ON SCREEN. CAN ONLY TURN IT OFF BY KEEPING MY FINGER ON THE POWER BUTTON ON THE FRONT. I HAVE A FUJITSU SIEMENS SCALEO P. THE MOTHERBOARD IS A ASUS P5GD1-FM/S.IF IT IS THE MOTHERBOARD CAN YOU TELL ME WHICH MOTHERBOARD TO BUY TO REPLACE IT WITH, BECAUSE I CAN'T FIND THAT MODEL.
  • 42 Answers
Open the PC and try reseating the memory and processor before condemning the motherboard. Also, as an FSC computer, check the processor is not one of the batch which had the incorrect heat sink fitted - if it is, you will be entitled to a free processor replacement form the FSC helpdesk.
Posted on Apr 30, 2009
Why doesn't my Dell XPS 8500 boot up?
hold the power button in for a count of 8 and it should shut all the way down. Then try and turn it back on
If it still does not boot, do you still have a warranty? Could be motherboard gone bad. Usually if it is memory or video your will hear beeps
Aug 05, 2014 | Microsoft Windows XP Home Edition
My Zoostorm Desktop won't boot and show up on the monitor. Help?
No signal just means the video card isn't putting out any signal. If you don't even see BIOS then replace the power supply first. Still doesn't work then it's probably the motherboard.
Jan 01, 2013 | Computers & Internet
I have a an Asus P4P800 Motherboard and when I boot up it is giving two short beeps, displays the motherboard screen, goes black, and then does the sequence starting with the two beeps again and...
first make sure the RAM is securely seated
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 17, 2011 | ASUS P4P800-MX Motherboard
LOOKING ONLINE, COMPUTER FREEZED SO I SWITCHED IT OFF BY UNPLUGGING IT, WHEN I SWITCHED IT BACK ON IT POWERS UP THE MOTHERBOARD, THE FANS START, THE DISK DRIVES OPENS BUT NO BEEPS AND NO IMAGE ON SCREEN....
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Jan 29, 2011 | Biostar K8M800-M7A Motherboard
Installed 2x GB memory and the computer just beeps-so removed the cards and still just beeps with no signal to screen
You get the 3 beeps if the memory is not detected, and the pc will not boot up. Make sure you are using the recommended size and type for the motherboard
Mar 03, 2010 | Gateway GT4016 Desktop PC
Keyboard and VGA port does not work,i think it's a motherboard
i think your board is dead you must wait 15 seconds to reboot your pc or you will over surge it with power my buddy did it to mine and blew up my graphics card your board might be dead but does it make a clicking sound when you try to start it or any beeps if not your board is dead you could try to clear the cmos just take out the round watch battry on the board for about 5 min and then put it back in and start it up but theree should be a jumper you can use to clear the cmos cmos is your pc's boot options you know when you hold the delete button and shows your boot options it will reset itself try that if nothing works your board is dead
Feb 11, 2010 | EliteGroup Goal 3 Plus/Sempron 3000+...
Had trouble booting the computer over time. Sometimes power light would come on and nothing else. By unplugging, waiting 15sec it would power up. Over time this stopped working. Eventually power light...
Time to look for a new computer. That and take out your hard drive to copy your files over.
Sounds like motherboard problem. Probably not worth repair.
I've got an HP desktop with similar problems. It turned on one day just fine. The next day not. I don't even get the boot up screens. Disconnecting Hard Drive and CD/DVD components do not help. I should at least get some BIOS POST beeps and a Hard Drive Not Found or such. I do not. On occassion it will boot to a blank screen with white cursor in upper left. Most the time no screen at all. On rare occassion it comes right on and boots Windows. I guess it could be the power switch ... but I doubt that.
Nov 22, 2009 | E-Machines eMachines Desktop PC
NO POWER
If you have changed the power unit and the computer is still not powering up, then it is quite likely there is a motherboard fault - probably in the power management circuitry, which expects the power_good signal from the power unit at a precise moment in the boot up process. A fault in the power management circuitry would prevent the computer from beginning its boot-up process.
Do the fans in the power unit come on when the computer is switched on? If they don't - this suggests a power unit problem. If the power unit fans do start working but the computer still doesn't boot, this suggests either a faulty or 'dry' connection (easy checked) or a motherboard fault.
If your computer 'works' but nothing is displayed, try pressing Control+Alt+Delete. If it then boots up it suggests a power unit problem. If not .. we come back to the motherboard again.
A low wattage power unit can cause the problem you describe. Every 128 Mb of Ram needs 4 watts of power. Add more for the motherboard (up to 30 watts..) then the floppy/hard drive/dvd etc .. If the power unit can't supply the necessary wattage, it won't boot. The older 250-300 watt power units aren't suitable for modern computers with XP/Vista. Ideally, you should be looking at 400 watts plus -it will tell you on the power unit.
Though to be honest, it does sound like a motherboard fault.
The only other thing that can cause a computer not to boot up (though it will begin the boot up process) are other faults ... When you switch on does it actually display anything on the screen .. and are there any 'beeps'? 1 beep indicates everything is ok .. 3 short beeps and 1 long beep indicate a memory problem (and the computer won't boot..). 8 beeps indicate a video problem (and nothing will be dislayed on your screen). Same with 9 beeps .. which indicates a bios fault - and the computer won't continue the boot process.
If you have nothing .. no power whatsover ... it comes back to the power unit/mainboard. If you're happy that the new power unit you have put in is ok ... suspect the motherboard. If you have access to any unwanted or 2nd hand motherboard ... connect that. If your computer boots up ... its the original motherboard at fault.
Alternatively, rather than replace bits and pieces at random to cure the fault, take your computer along to a computer shop. It will take them minutes to test it for you and identify the fault.
May 17, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Blank monitor screen
It appears that this motherboard has an on-board video port, I would recommend unplugging the video card and try using the on-board video. Make sure that when you do this, the BIOS POST screen shows, if it stops making the beeps, but still doesn't show anything, you might want to reset the BIOS (using the on-board jumper, sometimes also displayed as CMOS reset or password reset). If it still beeps, it might be the RAM, and you might want to see (if you have more than one stick of RAM) if you can try unplugging one or the other, or even switch their locations. Good Luck.
Mar 25, 2009 | ASUS Computers & Internet
Boot up problems
If it won't go past the splash screen, and you have replaced the CPU, I agree that it is probably the motherboard.
One other test you can do is, remove the memory chips, and any cards that are plugged it, and see if it beeps on start up.
If it does, count the beeps. If it doesn't it is the motherboard.
If you get beeps, plug the memory back in, and try again. Listen for beeps. Let us know what you find.
And I don't know if Compaq's do this (Dells do) when you turn it on, do the fans spin up normally? Or does it sound like a small jet? Speaking of which, do you see the fans spin up at all?
Aug 05, 2008 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Biostar K8M800-M7A Motherboard Logo
710 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
