Question about Jensen Car Audio & Video
Jensen cd3010x power but no sound
Power, but no sound through speakers, can hear a hum!!! Nothing will play, cd, mp3, or radio?
DrElectrics
  • 199 Answers
SOURCE: Eclipse headunit
There nay be a wiring issue with your amp. When you are running a CD more power and sound quality is envolved so the amp works harder. Check the amp make sure everything is where it should be.
Posted on Feb 13, 2008
  • 1894 Answers
SOURCE: Jensen radio; model#cd3010x
capacitors may be blown
Posted on Jun 10, 2008
SOURCE: Jensen CD3010X Radio Problems
This happened to me too--with the same unit. I finally took it apart and found that the volume up button was shot. The tiny piece of metal that makes electronic contact had actually snapped in the middle causing contact to be made at random by bumps rattles or just about anything. Since the unit automatically comes on when the volume button is pressed, even turning it off was ineffective. So...I unsoldered one of the buttons that I never used much and soldered it where the broken volume button had been. I'm no expert, so I was rather surprised when the unit worked after i reattached it in my dash. Anyways, it was a cheap fix for a cheap--and poorly made deck. good luck
Posted on Apr 12, 2009
trububbles1
  • 54 Answers
SOURCE: Jensen KDC 9520 Car CD player lost speaker conection
sound chip inside is fried
Posted on Sep 25, 2009
barnes07
  • 16 Answers
SOURCE: My Jensen MP3 CD3010X Player in an entertainment
pull it out and pull the wires out of the back via the conector
Posted on Apr 08, 2010
Speakers buzz with no sound
Is this only with CD, only with THAT CD, or with nothing in particular selected or playing?
Check all connections for tightness as bad cable shield connections will let emitted noise into the system. Ditto for signal or speaker cables routed near power cables, TV's, other electrical sources.
Sometimews reversing the AC power cord polarity can resolve buzz/hum.
Feb 20, 2010 | Philips HTS3440/37 System
My Jensen radio continuously seeks for channels,no reception.model#CD3010X
check to make sure your radio wire is pluged in to the back of your sterio and if it is take it out and clean the metal on it so that it gets better connection
Jul 12, 2009 | Jensen (654658) CD Player
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
The UV8 needs to use The Pink wiere to play an CD audio?
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
Nov 26, 2008 | Jensen VM9510 Car DVD Player
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
Mar 23, 2008 | Jensen CD4610 CD Player
Jensen head unit VM9311TS no sound from CD
Should wire HU's Power Const to Amp's Remote On. Instead you wired HU's Power Antenna to Amp's Remote On. So the stock amp got triggered only in radio mode.
Jan 24, 2008 | Jensen VM9020TS Car DVD Player
No sound with discs playing
There should be some sort of outboard amplifier. Mine had an amp at each speaker, and also a receiver mounted behind the passenger seat. Could it be that the power antenna lead from your headunit is connected to the amp turn-on lead? That way, when the radio is playing, the antenna lead is powered and thus the amps are too, whereas when the CD is playing, the antenna lead would not be powered and thus no sound. Try reversing these two wires (Power antenna and amplifier turn-on) and your CD should work.
Jan 21, 2006 | Jensen VM9410 Car DVD Player
Car Audio & Video Logo
62 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
