Question about Samsung TXK2754 27" TV
Screen problem TV has been working fine for several years but now an opaque black box appears on the screen. I can still see the picture around the perhiphery. It's the same size and shape as the menu screen but without anything in it. Pushing the menu button on the remote or the TV will make it go away but in a few minutes it appears again. In fact, pushing any key on the remote (such as volume) will make it go away for a few minutes but it reappears again. Help!
    Genius:
  • 1,074 Answers
Check captions on your menu settings it has caption 1 and 2 if it is not set on caption it could be on text which cause the black box to come on the screen turn off every thing on the caption menu.if that does not work then take you set to a tech to have it reset then it could be your eprom or your video circuit.good luck.
Posted on Mar 23, 2007
I have an LG model #60PK750 serial #010RMWV8M569, the other day I was watching and the screen went black and no sound, I did get a display on the screen that said lost signal.
Fixya is a free tech support site. There is mo shop. No replacement parts.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Apr 07, 2015 | LG Televison & Video
A black opaque retangular box appears on the tv screen
bfe2, check the cc settings on your tv, you might have te text feature enabled and you don't know it' this happens when thn the cc key on the remote control is pressed most of the time by accident.
Aug 26, 2009 | Televison & Video
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Jan 26, 2009 | Mitsubishi CS-40307 40" TV
Black box in front of picture
If it's the box,just press the CCD button on the controller until you see CCD off .(Try this one first since it just started with the box)
If it's the TV,just go into the setup options and turn off the closed caption feature.
Jan 07, 2009 | Insignia Digital-to-Analog Converter for...
Black box showing up while viewing DVDs
This sound like a problem with the Closed Caption, on many sets if the C.C. is set to text a black box apears, and since it only happens on DVD you might look at the DVD menu and see if it has this Text featcher in the Closed Caption menu and turn it off
Feb 13, 2008 | Televison & Video
Green screen
No! that is difinitely not an easy fix. there is something wrong with the picture tube. it is the part that emits light and colors. you need to bring that to a local repair shop.
hope this helps.
thanks.
Nov 19, 2007 | Televison & Video
Sound but No Picture
Perhaps your remote is set to video recorder?  Try that first, and if no response, try calling up a menu on your TV and look for the Picture Settings.
Good Luck.
Nov 03, 2007 | LG 37LP1D 37 in. LCD Television
Black box in middle of screen
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Sep 15, 2007 | Toshiba 36A60 36" TV
Opaque in viewfinder, screen and picture
There is no sensible fix - new camera time.
Jun 13, 2007 | HP Photosmart 945 Digital Camera
Black screen, small portion of top of picture in view at bottom of screen
your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good luck.you need the repairman.
Apr 01, 2007 | Sony KP-53HS10 TV
Samsung TXK2754 27" TV Logo
74 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
