Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Wont stay lit
I have the heater that will burn on diesel or keroseen. When I turned it on this year it started but after a few minutes of running it quit and blew a big puff of smoke. I turned it off and it did the same thing. I cleaned all of the fileters including the fuel filter and still the same relult. Any help would be appreciated.
When unit lights only runs 10 sec then shuts off
Posted on Dec 10, 2008
New kozy world natural gas heater. Pilot light wont stay lit snd heater flame wont stay lit.
Are you holding down the pilot light button long enough for the heat sensor probe to get hot and turn on the gas valve? It takes up to 3 minutes
Nov 20, 2016 | World Heating & Cooling
Have an electric Reddy Heater 55000 about 4 years old that we have been burning diesel fuel in. Laterly we have been having touble with it starting, takes many attempts, Also the fumes are so bad we can't...
It sounds like you are not getting complete combustion and need to adjust the air flow to the burner so it will have more air/oxygen to burn. You may try cleaning the fan and burner also.
Sep 26, 2010 | Reddy Heater-30-55,000 BTU Variable
Desa model tb103 wont stay lit.
at first i thought this was a bad flame rod but the fact that it burns on low and not on high tells me that it is not getting enough gas since it burns less gas on low. there will be a tap on the burner side of the regulator, take off the cap and turn the screw clockwise to increase the gas pressure. do this in small amounts until it corrects the problem. If you have or can get a manometer, the gas pressure should be set to @7 inches of water column
Dec 09, 2009 | Reddy Heater RLP100 Portable Forced Air...
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
Infra red heaters wont stay lit flame in the tubes
have you tried to heat up thermal couple for a couple of minutes. It takes a few minutes for the flames to actually starts heating thermal couple you might have to move thermal couple a little closer to heater flames
Jan 16, 2009 | Reddy HD30 Heater
CBP20T floor heater will not stay burning
It may be dirty, see link below for manual. I had the same problem and its now fixed.
http://12.153.20.74/manuals/107882-01M.pdf
Good Luck,
Boricuahbg
Dec 07, 2008 | Desa International CBP20T Wall Mounted...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
435 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
