Problem with Targa DVD HDD-5600x recorder
Hello Fixya I have a Targa DRH-5600x dvd / hdd recorder (bought at Lidl a few years ago). When we have a power failure the date / clock settings "disappear". I then have to reset the information. This is frustrating and annoying. I assume that there must be some kind of backup battery that needs to be replaced, to prevent this situation. If so, please advise as how to go about fixing the problem. Thanks, Mike
Targa DRH-5600x having problem HDD-DVD.keeps saying change recordable disc
I switched on it and only appeared "HELLO" on the display but the screen keep on black. What to do ?
Aug 15, 2010 | Televison & Video
Looking for a shop to repair my TOSHIBA DVD recorder
You can most likely remove the HDD and hook up to a PC with a USB - HDD dongle. This will/should allow access to the data on the HDD, this could then be copied off to the PC's HDD, and then converted or played, to do this you will have to get and install the correct CODEC, used to do this.
Jul 22, 2010 | Toshiba SD-H400
Hello, when dubbing from DV mini tape to HDD
well one solution may be the speed you are recording at. L.P. recording on a dvd often creates this problem. but usually it is when you copy dvd to dvd, not mini dvd to dvd
Never record more than 2 hrs on a disk
there are programs for a work around that reprocess the dvd vob file with adjustments for the sync.
could also be a hardware problem
is your mini dv long play source as well?
Cheers
Dave
May 18, 2010 | JVC SR-DVM700 DVD Recorder/HDD Recorder
No sound output on highlander dvd recorder/hdd(80g). We did have for nearly a year, but a month ago sound output stopped. ie. we can burn from hdd to dvd & play in another machine & it has sound -...
Ive just had the same thing happen to my highlander dvd/hdd 160g.
Mine lasted just over a year and I have lost the sound as well. It worked perfectly and No problems until sound suddenly disappeared
Nov 19, 2009 | Televison & Video
Hi, I have an error code 0x81170801. Can anyone
code.erreure.0x81170801.sur.mon.targa..drh-5400x
Oct 13, 2009 | Televison & Video
Question about LG RH9509W
yes you can, first you have to connect that HDD to your computer and transfer all u wanna, and your done!
Mar 11, 2009 | LG RH177 DVD Recorder/HDD Recorder
I bought a Magnavox 810H 160GB HDD/DVD recorder. It's a decent machine which worked perfectly for a few months, but now I can't get it to record to DVD. The HDD recording and playback functions work fine,...
Try switching it over to DVD . Because you may still have it on HDD when you put the disc in it may be that the unit is still thinking you are on HDD and don't recognise it as a disc just the hard drive
Sep 11, 2008 | Televison & Video
I Have a Targa DRH-5300x It take a full minute to load a DVD R disk for recording (HP dvd r 8x 120mins), and if I Put a DVD-R disk in the drive it looks at it for a while and then ejects it However if I...
My problem was solved.
After my previous post on Dec. 12, 2008, I called Targa UK who asked me to send the device to them. Within 3 weeks after I sent it, it came back fixed (it is still within the 36 month warranty).
Jun 30, 2008 | Televison & Video
I bought dvd hdd recorder 3 days ago from lidl it is a targa DRH-5700X seriel no. e5809000859. Imust not have it connected right as i cannot get anything from it on the television.Ihave the recorder...
i have a targa 5500x from lidl cant copy from hard drive to dvd as i have done this many times but the dvd drawer keeps opening telling me to put in blank dvd and i keep doing this but getting no where,
mary
Apr 23, 2008 | Toshiba SD-4000
Problem Recording HDD to DVD-R
I had a few problems with my philips 3450 - I downloaded the latest software upgrade at www.philips.com/support , and my issues were resolved. Worth a shot...
Only other thing I can think of is you may have a faulty batch of DVD-Rs?
Best of luck!
Jan 16, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
