Question about Kenmore Elite 45986 Front Load Washer
Ht3 washer spin cycle
Over the last one year the two front shocks of the washer have come loose and caused the washer to move and damaged the front door. What will prevent the shocks from coming loose?
    President:
  • Kenmore Master
  • 2,651 Answers
You shloud replace the shocks, i believe they're are updated part number 8182703
Posted on Oct 29, 2008
Could the spinning barrel be off center,what has come off?
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Mar 19, 2015 | Washing Machines
How do I fix the last few seconds of spin that vibrates off balanced and aloud noise.
Sep 23, 2014 | Samsung WF419AAW 4.3 cu. ft. Front Load...
I have a Samsung washer model number wf338aab/xaa my tub is off balance
Sep 17, 2014 | Samsung WF328AAW Front Load Washer
Why is my basket leaning to the side on my easing machine
Sep 06, 2014 | GE Washing Machines
After 23 years of good service the drum has fallen off at one side. Is it worth fixing or buy a new one?
HAS SHOCK ABSORBERS WHEN THEY GO BAD ONE SIDE CAN LEAN ALSO CHECK FOR BAD OR LOOSE BALANCE WEIGHT. LOCATED NEAR THE MOTOR.
Jan 28, 2014 | Asko W6221 Front Load Washer
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Broken shocks
the bearing may have failed on the tub-this may even have caused the shock to fail-the motor can't start the tub because there's to much restriction-cheers Denny
Oct 29, 2013 | Frigidaire FTF530FS Front Load Washer
My 7 year old he3 has a terible thumping noise when in the very fast spin cycle it is like the tub is coming out. The spin cycle before last is not as bad. the shock absorber are ok I can take the front of...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 11, 2011 | Kenmore HE2 Plus Front Load Washer
Violent spin cycle on the Frigidare front-loading washer
I assume you bought it new, so on that basis, did you remove the transit packing materials inside the machine ?
Front loading washing machine normal design is for the drum assembly to be supported by two or more springs at the top, and two dampers at the bottom. This allows the drum to move in a controlled fashion and also minimises vibration, particularly during spinning.
When the machines are shipped from the factory, transit packaging is put inside the machine to ensure that any shocks to the machine during transit dont damage the springs or dampers. This must be removed before use otherwise you get pretty much the symptoms you describe.
The manual that cam with it will show you how to remove the transit packaging. In such a short time I suspect you wont have suffered any damage, but take the transit packaging out as soon as possible.
Nov 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Spin cycle
Rear shocks tend to wear faster than the front.
Try switching the front shocks to the rear. If this helps, plan on
buying 2 new ones. You will have time to search for the cheapest price... typically 25 USD @ /www.appliancepartspros.com/
Dec 09, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
97 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
