Question about Maytag MSD2758GEW
Water leakage under freezer door-ice on bottom of inside of freezer
Water is appearing under freezer door periodically during the day. Inside there is a thin layer of clear ice on floor of freezer. I have cleaned the condenser coils and checked to see that the water is only coming from the one place. What is my problem and can I fix this?
Thanks!
L.C.
  • 1 more comment
  • lisbettc Oct 29, 2008
    Thanks, I will try your suggestion and let you know if it works. Sounds interesting. Not quite sure how to take off rear panel, but I imagine it will become apparent once I get everything out to see. Do I need to totally unplug fridge for this or can I just turn off freezer side?
    L.C.
  • lisbettc Nov 17, 2008
    Just an update. I followed your suggestion. The drain in the freezer was indeed frozen over. I made sure that it was totally thawed ,unclogged and dry before starting up and plugging in again and so far everything seems to be fine! THANKS!
  • p_wesely Feb 25, 2009
    I Have a Maytag and have similar problems with: water under door on the floor and thin layer of ice on the bottom of freezer.
    President:
  • Maytag Master
  • 2,651 Answers
Sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Oct 29, 2008
Water is puddeling under the left side and front of the fridge. its dry and dusty underneath. water line for ice maker has been disconnected for years. cant figure where the water is coming from
You have a side by side or a undermounted freezer? I am having the same problem with mine. Take a look into the bottom of the freezer, there is probably ice building up on the bottom of it under the bottom self or basket. It seems if the refrigerator door is opened frequently and it is moderately or very humid in your home the water vapour condences inside the freezer. There is probably a condensation tray somewhere that is overflowing into the freezer compartment. Once the ice build up on the bottom gets to a certain point the water then starts to run out the front of the fridge onto the floor. Remove the ice from the bottom of the fridge and empty the condensation tray. You may have to continually do this during humid periods. For me that is about 6 months of the year every 3 to 4 days. It's a pain but what are you going to do.
Oct 15, 2015 | Refrigerators
Freezer apparently wont defrost because it has that dry ice look. freezing fine
some times our equipment need rest !!! remove your food , unplug for at least two days, clean inside.after two days plug back
Mar 12, 2012 | Maytag MFD2560HES Bottom Freezer French...
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
Kenmore fridge, 7 yrs old, freezer on top. Water sprays periodically from somewhere at top inside of refrigerator, apparently from downward pointing chute or holes on either side. This seems to be part of...
Removed inside rear and floor panels of freezer (ice machine also) as ably advised by your tech. Found ice damming he suspected underneath floor panel. Thawed overnight with pot of hot water in freezer. could see that small rear drain tube was iced shut; why all water going into fridge below. Avoided floor mess from thawing water flow to evaporation pan on floor by tilting unit forward on blocks and laying several old towels inside freezer door to catch water that would run out. Also placed some in front at base of unit on kitchen floor. Continuing to thaw pipe to unclog, it is iced some way down, again as tech said it might. Will reassemble and be careful with freezer setting, in case it may have been too cold. Also, some food crumbs had found their way behind panel near this drain tube and may have fallen in to block it. Will clean out any remaining.
Jan 05, 2010 | Kenmore Refrigerators
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Leak running down front
Take the recess cup out and seal the area around it right where the front stainless steel panel meets the recess (right at the front of the recess) with clear silicone to prevent water from getting inside the door, then running out of the plastic frame area around the dispenser and running down the freezer door or out the bottom of the door. After the silicone has set, replace drip cup.
Nov 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MSD2758GEW Logo
321 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
