Question about Genius HS-03U Headset
Genius HS-03U Headset driver - Genius HS-03U Headset
2 Suggested Answers
SOURCE: Genius HS-03U Volume Control Help
It's not fixable.
Set as default audio unit to "USB audio device", because Genius HS-03U control the volume only sound device by default.
Headphones improperly trying to adjust the volume of "alien" audio devices, such as second sound card, if it is selected as the audio output device by default.
Posted on Sep 12, 2010
Looking for windows 7 drivers for the Genius hs-500x headset
The Genius hs-500x headset simply plugs into your headphone and microphone jacks on your computer.
The microphone jack is red and the headphone jack is green.
The audio settings are changed within the communication application you are using like skype or gaming.
Aug 03, 2011 | Computers & Internet
Am using win 7
So I'm assuming it's no working and you need the driver.
http://www.givemefile.net/drivers/headphones/genius/hs-04u.html
I've been told that the Vista driver works fine with Windows 7, please inform me if it does not.
Apr 19, 2011 | Genius HS-04U Headset
I need to repair my headset Genius HS-04SU. The volume control is not working
You can disassemble the volume control and clean it. The potentiometer is probably not making contact or is dirty - it is just a variable resistor.
Feb 24, 2011 | Genius HS-04SU Headset
When i try to connect my genius hs-03u's to my ps3 it doesnt work is there any way to make them connect
First, examine the connection receptables on the PS 3. For example, inserting the head set pin into wrong PS 3 connection receptable would not produce any sound discussable.
1. The PS3 device has several connection receptacles either for video audio output or video audio in put.
2. Video audio out put only gets sound and movies out of the PS3 device to be projected on to another device, e.g. projector, TV screen or Any out put devices.
Note: You solution is to connect the headset to the out put indication area keeping in mind not to connect to the Video receptable, else would be trying to output video signals to the headset.
Caution: You do not want to connect the headset pin to the Video Audio Input receptacle areas, because, you would be trying to send signals into the PS3 device rather than get sound out.
Important Notes;
Getting signals out of a device like PS3 is inserting the headset in this case, pin connector would be inserted in the INPUT Area; keep in mind your are tryinng to hear sound, SO connect the HeadSet PIN to AUDIO reception area on the PS3 device
The same techniques is achievable for all equipment requirign connection.
REMEMBER TO PHYSOCALLY LOCATE THE INPUT to OUTOUT area on the device.
Give the following proccess a try.
contact the manual of the PS3 device refering to the device connectivity chapters or
Systems diagnostic or malfunction chapters for technical material when required.
Dec 02, 2010 | Genius HS-03U Headset
When ever im playing and using the mic after a while what happens is that everyone goes like "AHHHH STATIC DUDE!" so after i use it for like 2-5 min it turns static unless i replug it then it goes back to...
Get a smidge of moly grease and rub in on your mic plug, then insert it into the jack. All static will be all gone. Insert and remove a few times if you have to, until the static stops.
Mar 21, 2010 | Genius HS-03U Headset
Genius HS-04U Error "The instructin 0x77c2a61d" referenced memory at"0xc0000128" The memory could not be "written"
Not a problem with the headset. It's a driver problem (software). The headset vendor should be notified of the problem so they can correct it. Chances are, however, the vendor bought the driver software from a third party and doesn't know how it works and can't support it, in which case you're out of luck. This is most often true of off-brand computer accessories from China.
This product has received mediocre reviews on Amazon.com, particularly for driver problems and lack of vendor support.
Dec 09, 2009 | Genius HS-04U Headset
It's not fixable.
Oct 20, 2009 | Genius HS-03U Headset
Where can i find genius headset hs-04u driver? the CD doesn't work anymore
pardon my grammat.. see the web at http://geniusnet.com/geniusOnline/online.portal?_nfpb=true&supportPortlet_actionOverride=%2Fportlets%2FsupportArea%2FproductCatalog%2FfindByModel&_windowLabel=supportPortlet&_pageLabel=supportPage&test=portlet-action download and exec
miy good bye,,,
Marcos Conttreras.
Mail: Marcos-C@latinmail.com
Sep 30, 2009 | Genius HS-04U Headset
Genius HS-03U Headset Logo
722 people viewed this question
Top Genius Radio Communications Experts
TO Lady
Tom Chichester
Are you a Genius Radio Communication Expert? Answer questions, earn points and help others
