Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Ghosting, image apperes twice when moveing verry slow
If some one head is on the screen and that person moves his head just a little then it appears to morph into the new position and you have the impression that there are two heads at once. the TV is connected to a sky digi box older type using a scat .
    Scholar:
  • 70 Answers
Make sure the box is displaying all channels whether you scroll up or down. If this is good. You need to check the cable connection, Coming from the network into box. Make sure check all connections replace if look faulty. defintely check the connection between television and box. If these are loose and defective means ingress is getting into signal.Ingress means off air noise, which cause ghosting. Check the connections
Posted on Oct 27, 2008
When watching fast moving action (particularly sports), there is a lag and the motion of the ball will not be smooth, instead it will flicker.
the VIERA TH-65PV500 has a lower refresh rate than most lcd and led tv's which will cause some ghost images to appear on fast moving images and can not be fixed
May 13, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Sony Bravia with really bad ghosting
The little board on top attached to panel.
Jul 05, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
A Ghost is moving my Mighty Mouse (screen saver turns off)
Chances are that the mouse is just drifting a bit. like, it's sitting still on the desk and the pointer starts moving on it's own on the screen. It's caused by dust getting on the optical receiver and drifting around on it. By no means is it a ghost though.
Jul 06, 2009 | Apple Mighty MA086LL/A Mouse
I cant operate my jama phone
the align cross is for you to set the cootdinates of the screen, all you have to do is press the pen on the cross as it moves on the correct centre of the cross, this will akkow the setup to continue, it needs a mark for the centre and the four corners. if you do that correctly it should move to the setup screen and continue, if it does not hat means you need to reprogram the phone
Feb 12, 2009 | i-mate JAM Pocket PC
Slow moving images on screen
either the TCON board or the panel is bad. Sony supplies the two parts as a unit so you will have to have them replaced together. Hope it is under warranty because it is expensive
Oct 19, 2008 | Sony KDL-32M3000 32 in. LCD Television
FX 5500
Hi.
This happen's due to lack of ram or slow processor.
What's your computers specification's.
Sep 30, 2008 | XFX GeForce FX 5500 Graphic Card
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Red shadow on screen double image
Well this is the fix for the usual Ghosting problem....
To bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "SHPos Reg B". It should be "10", change it to "11".
Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone
Jul 19, 2008 | Televison & Video
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
326 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
