Question about Cisco Photosmart C4780 Wireless AllInOne Printer With Linksys By Cisco WirelessN Broadband Router
Mirror image printing on hp photosmart c4780?
How do I set to mirror image print
Here is the manual for the printer: http://h10032.www1.hp.com/ctg/Manual/c00230474.pdf , but there is not a reference for mirror image printing. Check your application software for capability to mirror print.
Mar 06, 2015 | HP Photosmart 8150 InkJet Printer
HP Photosmart C4780 and Acer Aspire fight over web-based printing!
Try hard-wiring your laptop to the router with an ethernet cable as a test and then try printing, if you do not loose connection to the internet then the problem is probably that the printing is hogging your wireless bandwidth.
If the same thing happens with loosing connection to the internet try connecting to the internet real quick through another computer that is hardwired, you want to find out if the problem is a wireless one or that affects wired computers also. You might need a driver upgrade, you also might need to upgrade the firmware of the router
Jan 22, 2013 | Cisco Photosmart C4780 Wireless AllInOne...
My HP Photosmart C4780 makes the loud clicking sound. This just started and it still prints ok. Less than a year old.
There could be something stuck inside. Look inside and inspect to make sure there's no paper or anything else clogging in
May 20, 2011 | Cisco Photosmart C4780 Wireless AllInOne...
I need to print a mirror image
Do you want to print in Mirror Image ?
Follow the steps and you will be able to do so,
Click on Start button
Open Control Panel
Open Printers
Highlight the Printer icon name ( HP Photosmart C4680 All-in-One Series )
Right click on the Printer icon and Left click on Printing Properties
Under Advanced Tab click Mirror Image ON
Click Apply - Click OK
Try to print and it will print in Mirror Image.
Thank you for contacting Fixya
*Please rate this solution with thumbs up
Nov 20, 2010 | HP C4680 All-In-One Inkjet Printer
HP C4780 photosmart won't make copies. It will
this is the Correct link to download the Software by choosing the Operating system but if you say if you are not able to make copies, is it from the printer itself..
Jul 01, 2010 | HP Office Equipment & Supplies
Do I want mirror image off or on? HP photosmart
Mirror Image shoud be off always
Otherwise it will print otherway round
Regards Soumajit
Oct 12, 2009 | HP Officejet Pro L7680 All-In-One Printer
How to connect wireless HP Photosmart C4780
here is a general steps to connect a printer to a wireless network
http://www.castleink.com/_a-wireless-printer-setup.html
Hope this helps
Thank you
Oct 02, 2009 | HP Office Equipment & Supplies
How do I select mirror image (reverse image) from HP Photsmart
When you select Print and the Print window opens, select Preferences.
Click on the Advanced tab. Look for the "Mirror Image" option. It should be "Off". If you click on "Off" the drop down menu should appear to change it to "On". Click "OK" at the bottom. Then click "Print" on the Print window.
Don't forget to change it back when you are done. :-)
(Note: If the Mirror Image option is not on the Advanced tab, look on the Effects tab.)
Apr 22, 2009 | HP Photosmart C7280 Laser Printer
Cisco Photosmart C4780 Wireless AllInOne Printer With Linksys By Cisco WirelessN Broadband Router Logo
48 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
