How do I get bbc iplayer on my panasonic tx-l42d25ba, it's not on viera cast app
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
Posted on Oct 03, 2009
  • 630 Answers
SOURCE: Panasonic Viera retune problem
Make sure that you do a new install retune not an update the channels have moved around a lot
Posted on Oct 24, 2009
  • 15 Answers
SOURCE: viera link pop up problem...ANNOYING
You need to (either or both) change from Shop setting to Home, and turn off Viera Link demo.
Go into the menu, choose set up and re set to shipping settings.
Posted on May 29, 2010
  • 7 Answers
SOURCE: Panasonic TX-P50G20B How to connect Panasonic
You need to run a DLNA server on your Windows 7 PC, I recomend using a program called Serviio: http://www.serviio.org/
Simply download and install, select the folders that you want view on your TV and you should be viewing your films and pictures in no time.
Posted on Mar 08, 2011
  • 1156 Answers
SOURCE: Ive got a line down
HI,
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
GOOD LUCK IN RECTIFYING THE FAULT, THANKS
Posted on May 13, 2011
How do i use the bbc i player app installed on the tv
There are several different versions of BBC iPlayer which manufacturers use in their devices. Between these versions, due to technical limitations, there can be some variations in features (subtitles, HD etc.). Each device will need to be connected to the internet to use BBC iPlayer.
Without knowing the make and model this is the info available.
Dec 23, 2016 | Televison & Video
Tip
How to Crack/Wipe DRM from Downloaded BBC iPlayer Programs
Quoted from: iPlayer ripper
BBC iPlayer - A service that lets you catch up with radio and television programs from the past week of BBC. BBC iPlayer use Microsoft's "Play for Sure" DRM system as copyright protection, thus the programs are downloaded, they will self destruct after 30 days because it is 'DRM License protected'. And once played you have up to seven days to finish watching the program. BBC Content will be automatically deleted from your computer once its expiry date has been reached. If you are outside the UK and connected to the internet you can only listen live and listen again to most of our radio programs.
BBC iPlayer Ripper - Daniusoft DRM Converter makes it easy to remove DRM protection from downloaded BBC iPlayer programs, such as DRM protected WMV video files, to make these programs DRM free and non seven or thirty days time limited so that we can save BBC contents permanently, Or you can Rip BBC iPlayer programs to any portable devices like iPad, iPod, PSP, Zen, Walkman, etc? Or even can we burn the files downloaded from iPlayer to DVD disc.
In the following passage I am going to show you how to use Daniusoft DRM Converter to remove DRM protection from BBC iPlayer programs step by step.
Step 1: Free download Daniusoft DRM Converter. Install and launch it as what you usually do with other application software.
Step 2: Click the "Add" button to import downloaded BBC iPlayer programs files, or directly drag and drop them into the main window.
Step 3: Then click the low-right "Setting" button, on the setting board there are many options to costomize the output audio & video properties. Choose an ideal output file size and quality to meet your players' requirement.
Step 4: After finishing the settings, backward to main interface, click "Start" to begin the conversion process. When conversion done, you go with DRM-free BBC iPlayer programs in various formats, or enjoy BBC iPlayer video music on any portable devices like iPad, iPhone 4, iPod touch 4, PSP, Zen, Walkman, etc?
__________________________
remove drm from wmv ' iplayer ripper ' remove drm from itunes 10 ' itunes to droid ' Transfer itunes music to htc evo 4g ' wmv to ipod touch 4g ' drm removal ' convert m4p to mp3 ' amazon video on demand ipad ' remove drm from itunes
on Oct 18, 2010 | Computers & Internet
Won't allow me to download bbc iplayer app
then I guess you will live without it EH
Jun 13, 2015 | Android Apps
How to find iplayer on Panasonic viera
Iplayer is a third party application and may not come installed on all devices by default. Iplayer is a UK only application and can not be installed on devices outside the UK.
If you are in the UK you should be able to install iplayer from your tv's applications center It may be called (BBC Iplayer)
Nov 20, 2014 | Panasonic Televison & Video
WHY CAN'T I "LISTEN AGAIN" TO LOCAL BBC RADIO,VIA BBC iPLAYER?
Can you provide a link to the app? I looked and didn't find anything official for Android.
Mark
Motorola Support
Sep 03, 2014 | Motorola Mobility Moto G 16 GB Black...
Using Ex Pat Shield, BBC progs no longer start and a notice, 'Task failed at step 0: config was empty.' (Or 'Task queue failed ditto' Everything worked fine just days ago.
I have exactly the same problem, same error message. I first noticed the problem yesterday (September 11). Error message appears when trying to watch live TV through iPlayer. BBC News Channel works OK from BBC News website. Live sports broadcasts work OK through BBC Sport website. I uninstalled and reinstalled Flash Player but it made no difference.
Sep 12, 2011 | AnchorFree Expat Shield
I cant't get bbc iplayer to play programmes: it comes up with: task queue failed at step 0: config empty. ITV player works perfectly but I prefer programmes from BBC. What can I do to solve this...
I am having the same problem,same error message. I only get the message when trying to view live TV using the iPlayer. The BBC News channel plays live OK through the BBC News website. Live sport broadcasts play OK though the BBC Sport website. I uninstalled Flash Player and then reinstalled. It made no difference. Please help.
Sep 11, 2011 | AnchorFree Expat Shield
I have a Panasonic Viera TV Model No> TX-L32D26B and suddenly have no signal for any of the BBC channels. What do I do?
Try reprogramming your set if you have not already. If that does not work you might want to adjust your antenna.
Apr 07, 2011 | Panasonic Viera TC-37LZ85 LCD TV
Panasonic TX-P50G20B How to connect Panasonic Viera TX-P50G20B with Windows7 as a media server. The G20 is connected to the network, Viera Cast is working, I can also ping the g20 from my PC. When...
Mar 08, 2011 | Panasonic Televison & Video
Televison & Video Logo
403 people viewed this question
Top Televison & Video Experts
Electro Med Services...
