Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanning I have an hp officejet 6110 xi all in one printer. When I lay my picture down to scan, push the "Start Scan" button, nothing happens. It says scan error and to push the "enter" button. Can you help?
  • 1,124 Answers
Try using the scan program provided by Hp already installed in your computer.
Double click on "My PC" select the OfficeJet scanner icon and do a the right click, and then order to a scan.
Posted on Oct 27, 2008
How to scan a document
turn on your scanner
click start all programs look for your scanner open it up
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it and what format browse select the file/folder where you want to save it (my pictures) most common
hope this helps
Feb 11, 2011 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6110 - Scanning Error. Cannot connect to PC
Uninstall and Reinstall the software
1 On the Windows taskbar, click Start, choose Programs or All Programs
(XP), choose Hewlett-Packard, choose hp officejet 6100 series, then
choose HP Uninstaller.
2 Follow the directions on the screen.
3 If you are asked whether you would like to remove shared files, click No.
4 After the program finishes removing the software, disconnect your
HP OfficeJet, and restart your computer.
5.Do not reconnect the Officejet now
6 To reinstall the software, insert the HP OfficeJet 6100 Series CD-ROM into
your computer’s CD-ROM drive, and follow the instructions that appear.
7.After the software is installed reconnect the usb cable and allow the
computer to detect and install the software
If this doesnt work then get back to me
Nov 27, 2007 | HP OfficeJet 6110 All-In-One InkJet...
No response when printing or scanning
You have a bad scanner assy which will cost more to replace than a new printer.
Jul 02, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Inability ro scan to new laptop
Before scanning from the printer front panel, make sure your Solution Center is properly installed. Try scanning from the Solution Center first. The status of the printer should say ready before scanning.
Mar 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner problem
Hi s2009edwards, double check the USB data cable from the printer to the computer. Power off the printer. Than, unplug the data cable connected to the printer & re-connect it. Follow the data cable to the PC & unplug the cable & re-connect it. Power on the printer & wait until its done making noise. Try scanning again. If it fails to complete & you receive the same error message than buy a new printer data USB cable & replace the old one.
If the HP director software is installed (Which it should be).
You can open HP printer software there should be an HP icon down by the clock. Right click on it once & left click open or launch. If you did not install your HP printer software suggest you do so.
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Can't scan with HP Officejet 6110 from document holder
well u can try:
1/uninstall and install printer/scanner drivers and software.
2/ replace the usb cable.
3/make sure that there is no damage va been maen on th AIO cuz u need a warrantly in this case.
plz do rate this post.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6110 xi All-In-One will not scan
This is an interesting problem because a printer isn't "intelligent" the way a computer is "intelligent". While devices such as the 6110 have RAM and thus "memory", they don't have the ability to recognize which devices are connected to it, as such. That's why you have to install all of the HP software and drivers onto the Windows or Mac machines, so the burden of recognition and interfacing is on them.
That said, information and even errors can be stored in a printer as long as it's receiving power...sometimes even when they're turned off.
My first suggestion is to completely turn off the 6110 and unplug it both from it's supply of power and from any computers.
Let it set for around 30 seconds to a minute so that any residual power from the "brick" dissipates.
Reboot the Windows computer.
Then plug the 6110 back into it's power supply and attach it back to the Windows computer.
Power up the 6110 and let it go through it's start up and alignment routine.
Try to scan again as you originally did before you tried to us your Macbook with the 6110. Hopefully that will do it.
If, for some reason, the Windows machine is still not able to interface with the 6110, you may have to completely uninstall all of the HP software and drivers from the laptop and reinstall them using the original installation CD, just as if you were installing the printer with the laptop for the first time.
This means (assuming you have Windows XP), going to Start -> Control Panel -> Add or Remove Programs. You'll need to go through the list after "Add or Remove Programs" opens to select and uninstall all the software and drivers that have anything to do with the 6110. Hopefully, this'll be just one or two selections.
If you have the original CD, you can also insert it and it should offer you the option to uninstall the original software and drivers. That would be the easiest. Then you could just turn around and do a reinstall from the disc, no muss, no fuss.
If you do not have the original CD (and believe me, these things get lost all the time), you can still download all the latest software for the 6110 onto the Windows laptop by going to this web page at
Officejet 6110 Software and Drivers
Once you go to that page, you'll need to select your particular Windows operating system name. You'll be taken to the web page where you can download the installation software and the latest drivers. Once they're reinstalled onto your system, you should be good to go.
You "may" be able to install the latest software and drivers without uninstallng the old stuff first (that is, you could be offered the option to overwrite the old software when you install the newer software),. but that's not as "clean" and instead of curing the problem, it could make it worse. If you're a risk taker, go for it. If not, don't take the chance of more headaches.
I probably made this sound more complicated than it is. Good luck and post back your results.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning problems w/officejet 6110
Remove the HP software then reinstall the software from HP's site
Sep 24, 2008 | HP OfficeJet 6110 All-In-One InkJet...
when you scan file/s use the scan program not scan button and has feature what you will scan before it goes on processing.
Sep 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
No Scan Options Error Message
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  3. Click Accessories .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
168 people viewed this question
Ben Johnson
