Question about Garden
Toro timecutter 1642z zero turn mower recomended oil and oil filter
Recomended oil and oil filter
#1 Taper
  • 1040 Answers
SOURCE: My Toro Mod20070 does note start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. You can also use the Den Tek Brush to clean the jet in carb. if it has one. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • 1129 Answers
SOURCE: Toro lawn mower. Have trouble starting(starts and
Remove the float bowl located under the carburetor it is a 1/2 bolt some gas will poor out so put a rag under the carb to soak up the gas, you actually may want to use a small container to collect the gas or make sure the gas tank is empty, remove the float bowl after removing the bolt by grasping it and turning, the bowl will most likely have debree and water in it clean with a rag and solvent and reinstall, becareful of the ruuber ring gasket when reinstalling the float bowl, one some movers there is no float bowl if you have this type of engine the tank and carb must be removed disassembled and clean out. Do not store mowers uncovered they must be covered when not in use, water gets into the fuel system and causes this problem.
Posted on Jul 14, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
  • 54 Answers
SOURCE: Trouble starting and a lot of black smoke at startup
Could be. Black smoke means too muck fuel or not burning properly. Also make sure your oil is not over full.
Posted on Apr 28, 2010
miket756
  • 2702 Answers
SOURCE: I have purchased a Toro zero turn mower and can't
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Posted on Jul 27, 2010
Timecutter ss5000 loses power
check for rusted or failing bearings on the cutter shafts
Oct 02, 2016 | Toro TimeCutter SS5000 zero turn mower
Left hand drive handle hard to move forward
drain and replace your hydraulic steering system oil and replace the hydraulic filter then refill system
Jan 26, 2016 | Toro TimeCutter Zero Turn Lawn Mower...
How do I replace an idler pulley on mower deck on toro timecutter mx 5060?
Release belt tension, unbolt the pulley, replace it with a new idler pulley. If you need more help, please follow up here.
Jul 29, 2014 | Toro Zero Turn TimeCutter MX Series MX4260...
Toro str will not start, motor spins but will not fire
Ensure clean fuel. Always use Stabile in fuel. Follow fuel line from fuel tan to carb, ensure no leaks. Remove carb fuel bowl to check float operation. Have pliers to crimp line or use fuel shut off valve. Remove carb float bowl and clean. Float should hang down freely gas should flow. Push float up gas should cut off. Replace spark plug, ensure plug wire snaps on tight. Clean or replace air filter. Ensure oil is full, 30w oil. All mowers have low oil shutoff.
Sep 12, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
1642Z won't turn over
jump direct to the starter if it cranks over check the safety swithes
Aug 11, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Toro cutting off
Maybe low oil level, all mowers have a low oil cutoff. 30w oil.
Aug 07, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Apr 26, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Garden Logo
194 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
