Question about Garden
Adjustment on clutch 5225 johndeere tractor
Newer tractor just need to make a little adjustment to cluth slipping a little bit .
4 Suggested Answers
gisvc
  • 40 Answers
SOURCE: drive belt slips on lawn tractor, cannot see an adjustment.
hi,
i would check with the owners manual to see if it shows an adjustment for the belt drive. most mowers today are equipped with a self adjusting arm witha pulley tensioner with a spring attatched to it. as the belt stretches the tensioner spring pulls against the arm causing it to apply tension to the belt thus tightening it. it sounds as if your belt is stretched beyond the limits of the tensioner. at least every new season it would be a good idea to inspect the belt tensioner for room or space of free play. that is to check to see if it will move opposite the pulley allowing the belt to tighten. if there is not enough sufficient room then i suggest replacement of the drive belt.
Posted on Mar 29, 2009
wadembly
  • 513 Answers
SOURCE: My Johndeere 2510 pto will engage. But you have to
its actually the clutch not disengaging enough for pto to engage or the teath are worn down on pto shaft
Posted on Jun 05, 2009
mattofilms
  • 110 Answers
SOURCE: I just purchased a 2440 john deere tractor it was
would say that your variable displacement pump has rust or other on/inside, it.
Are you using hydralic fluid (not eng oil) in her?
Can you let it run on blocks for a bit - drain and re-fill transmission?
Posted on Jul 02, 2009
How to adjust clutch levers
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Oct 26, 2016 | John Deere Garden
How to adjust the slip clutch on a heston swather 1360?
Your manual should tell you. Most of time, tighten the nut a little.
Jun 26, 2014 | Garden
Cluth trouble
Need clutch adjustment
Dec 16, 2013 | Garden
Hi. My clutch slips when standing still at a steep hill and you can hear the screetching sound. Help needed.
oil on clutch plate or disc is at wear limit, either way you need a new clutch. Check free play adjustment of cluth pedal, too tight will increase slippage
Sep 16, 2010 | Volkswagen Jetta Cars & Trucks
Cluth is sliping on my bike when u give it gas is there a way to adgust it so it dosent slip
If there's any adjust ment left, you can adjust down where it attaches at the cluch lever on the right side of you bike using a wrench, but if the cable is already at the max, then you'll need a new clutch kit which is relatively easy to do with some basic hand tools. Loosen your clutch cover bolts and remove the cover then remove the clutch basket and reinstall new friction disc's and clutch plates in exact same order as old one sit's in there. Then fill'er back up with some fresh oil and adjust it out. Be sure to leave a little free play at the lever. Good luck.
May 30, 2010 | 1996 kawasaki VN 1500 Vulcan Classic
When gasing the engine tranny slips
If you have a manual transmission it is time to replace your clutch. If you have an automatic transmission it is time for a transmission rebuilt. You can have your auto trans fluid and filter changed and this might help, but I doubt it. There is very little you can do for a slipping clutch in a manual tranny except replace the clutch. If you have a manual tranny with a clutch that is manual adjusted then the cluth may be out of adjustment, but I doubt you have a manually adjusted clutch it is more then likely hydralic.
Apr 08, 2010 | 1997 Mercury Sable
Clutch Adjustment 1200R Sportster 2004
Slide the rubber cover off the adjustment nut on the clutch cable, loosen the lock nut adjust the cable until you have about an 1/8" play in your clutch cable at the lever. To adjust the clutch itself remove the derby cover, then the spring and retainer. Turn the post until snug and then back off a quarter to half turn, reassemble the derby cover.
May 05, 2009 | 2004 Harley Davidson XL 1200 R Sporster...
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
