Question about Frigidaire FGGF3042KF Stainless Steel Gas Range
Can you convert a BGGF3042KF gas range to propane
3 Suggested Answers
  • 10 Answers
SOURCE: changing gas to propane
You will need to contact your local appliance parts store with your model and serial number and see if a lp conversion kit is made for your unit. you will also need a monometer to check gas pressures.
Posted on Mar 07, 2009
heatman101
  • 43501 Answers
SOURCE: We converted our natural gas range to propane.
There is a regulator...usually on the gas line where it enters the range... this needs to be converted also or the gas pressure will be too high...
To convert it the center needs to be turned out and the center flipped over and screwed back in...
This will lower the gas pressure
heatman101
Posted on Apr 10, 2010
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
Ge j2s968 convert to propane
On the back of the range there should be a conversion kit with intructions on how to convert from natural gas to l.p. good luck..
Nov 05, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
HOW TO CONVERT IT TO GAS PROPANE?
Your propane supplier can re-jet your stove to accomodate propane. Give them a call ... they will probably do it for little or no charge.
Jul 06, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Maytag Range Model MGR5870 how to convert to propane
set the regulator to propane and change the orfices to the blk ones. copper is for nat gas / black for propane .. thanks hope this helped .mm
Dec 22, 2009 | Maytag MGS5870 Gas Kitchen Range
Converting a Propane Thermador 36" range to Natural Gas
I have the same range but need to convert it from natural gas to propane....we should trade...9j antiques
Aug 31, 2009 | Thermador PGR366 Gas Kitchen Range
Coversion
all i for sure is that for propane gas you will need smaller burner jets because of the higher pressure. ive done this the other way around, converting from propane to natural gas by drilling the jets bigger with tiny drill bits
Aug 01, 2009 | Kitchen Ranges
Converting to propane
Call Dynasty / Jade ph # 800-884-5233 order convert kit from Nat to LP. Flip the cap on the gas regulator from Nat to LP, talk with Brad @ Dynasty if you needed help. Have fun.
Mar 22, 2009 | Dynasty DGRSC 48-4GCB Gas Kitchen Range
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire FGGF3042KF Stainless Steel Gas Range Logo
340 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
