Question about HP Deskjet 3915 InkJet Printer
HP 3915 paper jam error
I have a paper jam error for my hp3915 deskjet printer but there is no paper in the printer. How do i get rid of the error.
I had the same problem and just talked with HP technician Neeta and she showed me how to fix it. It's a bit convoluted. In essence you have to clear the print spooler. Here is what she told me.
First you have to be clear that there really ISN'T a paper jam by printing a test message this back door way.
Neeta : The USB cable should be disconnected. Neeta: To print a self-test page, press and hold the Power button. Raise and lower the printer cover four times. Release the Power button, and the self-test page prints
If the sel-test page prints, this means you truly do not have a paper jam. Next, clear the print spooler
Neeta : The USB cable should be disconnected.Neeta : Now click on start->RUN.Neeta : Then type "services.msc".Neeta : Then it will open the services window.Neeta : Now please look for the option "print spooler. Neeta : Okay, now , please right click on the option "print spooler" and click on stop then click on start, 3 times.
Posted on May 04, 2009
  • Sharon Howell Dec 10, 2011
    This still works! Only correction is to plug in the USB cable when you clear the print spooler. I am grateful to Neeta and all who give us technology challenged aging boomers such great directions.
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Cant install driver for deskjet 3915
did you use 39xx series driver? Torn on your PC, insert the CD Driver, plug the usb printer cable in, the PC should detect finding new hardware that is HP Deskjet 3915. When asked to install driver, chose install from CD. Follow the instruction and good luck
Apr 10, 2010 | HP Deskjet 3915 InkJet Printer
When I try to install the printer with the CD all
go to download drivers on hp site maby cd faulty
Oct 07, 2009 | HP Deskjet 3915 InkJet Printer
Paper jam in my printer
the paper sensor may have went in the printer try doing unplugging everything and plugging it back in
Jun 29, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet 3915 Printer ''Door Open''
open all the doors (fron and back) make sure there is no paper jam .
close all doors, one at a time.
turn off, wait for a few seconds,,,
turn on
and your problems is solved.
Mar 26, 2009 | Office Equipment & Supplies
Paper jam
there is a sensor which detects if there is a paper jam in the printer.that sensor is bit moved from its orignal position so it is continuously detecting the paper jam in your case.
Oct 06, 2008 | HP DeskJet F380 All-In-One Printer
Failed to Print error
clean the buffer before fiving print and then restart the system. If the problem occurs same then reinstall the printer driver and then try to print
May 05, 2008 | HP Deskjet 3915 InkJet Printer
HP Deskjet 3915 InkJet Printer Logo
1,703 people viewed this question
Ben Johnson
