Question about Mitsubishi WS-55857 55" Rear Projection Television
Philips 1080i xbox 360 hook up
ok so i just fixed my tv now i'm trying to hook up my xbox 360 to the hd spots in the back. i hook them up and turn it on and it looks staticy and the picture moves diagonal i can hear everything fine so the audio is working. i've tried a bunch of different things but can't get a picture on the hd spot. what am i doing wrong? the tv is a philips 60pp920217f 1080i. i've tried to set it to 1080i in a normal video spot then hook it up to the hd but it didn't work. any suggestions would be appreciated.
  • Anonymous Dec 26, 2008
    me too but i dont know wat to do
  • 38 Answers
You need to change the settings on the xbox aswell.
go to your settings menu and change the picture settings to 1080i
Posted on Oct 27, 2008
Can you hook up a Xbox 360 (EU) to a Philips 37PF9975 37 in. HDTV-Ready Plasma
do one thing...see at the connector...there is a switch...do it normal mode...if it is in HD mode..it cant be work in ur tv..
Sep 23, 2012 | Philips 37PF9975 37 in. HD-Ready Plasma...
I have problem viewing my philips 60PP9363H in 1080i
Call Mats for original phiilps hand unit 1-800-628-1118
Apr 01, 2009 | Philips 60PP9363 60" Rear Projection...
Xbox360 hd hookup problem---1080i
Your component cable is probably switched to the HD setting. You have to switch it back in order to get video when hooked up to a regular TV.
Jan 30, 2009 | Mitsubishi WS-55857 55" Rear Projection...
RCA D52130 52 in. Won't Display High Def
Hi!
I doubt you'll look at this 2 years later, or even have the T.V.
I have the same TV and was able to view ps3 and xbox 360 games in 1080i, but it's a little tricky. First, let me say that the ps3 is probably not the best system to try using 1080i in unless you have a 360 to help trick the tv into working.
Xbox 360
You need to first set the video to 1080i. This will make the screen display in a bunch of horizontal lines most of the time, but if you keep toggling it on and off, it eventually works. To avoid having to sit and swap between the two modes, it's easier to first set it to 1080i and confirm the setting, then go back into the settings, select 720 (first option above 1080i) and cancel as soon as the video mode changes. 95% of the time this will make it display correctly in 1080i mode. If you turn the tv off and back on, it will sometimes reset to the horizontal lines. If you restart the xbox, it will reset to horizontal lines most of the time. With the ps3, you can set it to 1080i and keep toggling it until it works, but when the game launches it can screw up again, so it's best to have the xbox on and ready with a component switch so you can fix it with the xbox then switch back to the ps3. I think the cable that comes with the tv for HD input (the component plugs don't work, they only support 480, but the vga looking input supports 1080i) - the cable is just poor quality and can barely handle the signal. I've been trying to find a better quality cable with no luck.
Hope this helps other people with this ancient beta HD input canadian tvness.
Dec 30, 2008 | RCA D52130 52" Rear Projection Television
No picture
with the x box 360 it defaults to 1080p and this model does not support that resolution. connect xbox with composite cables and go into x box menu and lower resolution to 1080i and source tv back to original connection and should have picture
Aug 02, 2008 | Philips 42PF9630A 42 in. Plasma Television
Xbox 360 or Dish ViP 622
when i hook either my dish hd receiver up to the 1080i component video inputs, everything works fine if i set either device to 480p, but i get nothing i set them to 1080i.
Apr 09, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Hitachi 53SDX89BA HD settings
Problem more than likely with the xbox, as the output stream of data from the game platform is not always consistent...accordianman
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hooking up a console
well i would run it throw direct to tv ok then digital out from tv back down to this digital inn ok of samsung use hdmi to hd tv fro xbod 20 tims better looking
Dec 29, 2007 | Samsung HT-X50 System
Xbox 360 screen cut off on left side
Ok, I've had the same issue and I was able to fix my problem. I was getting cut off sides in HD mode on my playstation.
I entered the service menu by doing this:
Turn TV Off
Use remote and hit "Mute 1 8 2 Power" (not at the same time, but one after the other)
The TV will come on with the service menu. Enter the 1080i adjustment screen. Write down ALL the values in case you mess up. Adjust the values as necessary to fit your screen. It's sort of like adjusting a computer monitor's image for different resolutions.
Hit me if this helps... mlager at sysnosis dot com
Sep 20, 2007 | Samsung TXN3071WHF 30" TV
HD resolutions
Your TV would have to be HD ready and will automatically set itself to 1080i, but if you go into the XBOX 360 console settings' the top menu enables you to change resolution, but if the x box does not recognise 1080i it will not show up. See if 720i shows up as this is still High Def. and also that 60 Hertz is the setting and not 50 hertz
Dec 30, 2006 | Mitsubishi WS-55857 55" Rear Projection...
Open Questions:
Mitsubishi WS-55857 55" Rear Projection Television Logo
649 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
