Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
My frigidare electric range (ES200/300) made a loud popping sound and tripped the breaker. My son said F something was on the screen and it was beeping after they reset the breaker. They unplugged it. When I returned home and plugged in it was flashing door lock - I simply held clear and display returned to normal. Clock works, timer works, stove top works. No bake, broil or oven cleaning. Is there an internal safety that it some how tripped?
2 Suggested Answers
  • 1891 Answers
SOURCE: Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Posted on Dec 04, 2009
While preheating my electric frigidaire smooth top oven, we heard a loud pop and saw a flash. The breaker had tripped. After resetting it, the clock and digital features still work, and so does the st
I appreciate your inquiry, Stephanie Givan!
From what you are describing it sounds like a possible short with your breaker box or issue with your terminal block within your Frigidaire range. I would recommend reaching out to a professional technician for a proper diagnosis to be completed. The technician will have the correct tools to check for any electrical issues within the range to make sure the correct component is being replaced. This will help avoid any unnecessary part purchases. -Matt
Nov 12, 2014 | Frigidaire Ovens
Frigidaire plef398dca
Hello Bill Robbins - From what you are describing it sounds like a wiring failure or a communication break failure between the power board and UIB has occurred. Error code F5, typically indicates that the EOC will need replacing. A certified technician will need to test the wiring harness between the ESC, UIB and EOC.
Jan 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Fridgeaire 316246639 model popped oven does not work. Time clock does not work, burners work.
Hello mrstrini2 - Do you have an electric or gas range? Most fault codes consist of both letters and numbers. Could you provide me the code to better address the issue at hand?
Jan 20, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
During self-cleaning cycle we heard a loud pop and it tripped the breaker. Oven and stovetop (ceremic) still work but we smell the same smell from that cleaning cycle like electrical burning? Is there any...
If any appliance trippes the breaker there is a problem that has to be looked into, no appliance should trip MCBs or RCBs (trips), ISOLATE THE MAINS POWER BEFORE REMOVING ANY PANELS
A visual inspection of the rear is required, also the electrical mains connections. Look into this do not use the appliance until you have resolved the problem, it may turn out an amount of food had been stuck beside one of the heating elements, and causing a smell, better to be safe.
Let me know if you require any further assistance.
May 20, 2011 | Frigidaire Ovens
Frigidaire gallery stove, oven not working,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
Frigidaire Gallery ES340 electric range, burners will not turn on
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
69 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
