Question about Icon F701WL 7 in. Car Monitor
Screen is blank?
Hi, I was on a trip and when we dropped down the screen to head home there was no picture (all black) when we looked at the DVD player itself the lights are on but it also will not accept a dvd to play, what could be the problem? This unit is barely 6 months old if that. Thanks in advance, Mike
    Master:
  • 669 Answers
The unit should be under warranty and should you disturb the case in any way, the warranty will be voided. Make an effort to somehow get it back to the manufacturer for service. Do it ASAP to avoid permanent damage whereby you will be responsible for the cost of repairs.
Posted on Jan 12, 2018
When I look to the viewfinder I have a blank screen
Viewfinder, screen and pictures are blank / black - Nikon ...
https://www.ifixit.com/.../Viewfinder,+screen+and+pictures+are+bla...
iFixitMay 4, 2015 - When I look through the viewfinder or at the lcd it is blank / black. Also when I take a picture and view it on my computer, the picture is blank ...
SONY ' eSupport - There is no picture or a black screen ...
https://us.en.kb.sony.com/.../there-is-no-picture-or-a-black-screen-appear...
Dec 8, 2015 - There is no picture or a black screen appears in the viewfinder or LCDwhen attempting to ... Look to see if an image can be seen in the viewfinder or LCD. IMPORTANT: Some camcorders have both a viewfinder and LCD.
There is no picture or a black screen appears in the ...
Jan 11, 2016 | Cameras
I dropped my phone and now I haver no picture or anything blank screen
Press and hold down the Sleep/Wake button and the Home button simultaneously for at least 10 seconds. The screen will clear out and then the Apple Logo will appear on the black background. When the logo appears it means that the reset is done.
May 03, 2011 | Apple iPhone 3G
I have a blank, black screen, irrespective of the input (cable, dvd, wii). The menus, however, come up fine and the audio is working fine.
Your screen is showing a black picture because the closed caption function has been activated. When the closed caption mode is on the screen will display an 80% black picture.
To turn off the closed caption and regain a full screen please follow these steps;
1) Press the Menu button
2) Use the up and down arrows to navigate to Closed Caption
3) Use the right or left arrows to select it.
4) Use the right or left arrows to select OFF
5) Use the up or down arrows to select Finish
6) Use the right or left arrows to save the settings and exit.
You should have your full screen back now minus the annoying black box.
If this solution has helped please do take a moment to rate it.
Thanks for using FixYa
Dec 25, 2009 | JVC AV-32D305 32" TV
Canon digital camera led screen stopped working..did not drop or leave in sun..is just blank..canon powershot A590IS
I had this same problem. Once I got over about 1200 pictures, the screen just turned black, and the only setting that would work where I could see the lcd screen was the easy setting. I had read somewhere that this was due to the amount of pictures the camera had "counted", even if those pictures had been downloaded and erased from the camera. So I decided to reset the camera. Go to the tools list in the menu, scroll down to "reset all", and when it prompts if you want to "reset settings to default" click ok. This worked for me, and all of my settings - sunset, landscape, etc. - now work. Keep in mind that if you have configured any parameters in any of the settings (shutter speed, lighting, etc.) those will have to be reset.
Aug 31, 2009 | Cameras
Ewd2202 dvd/vcr combo when i put a vcr tape i can
the video heads are probably dirty.there is a steel drum 1/2 inch thick that you can see if you look thru the front lid where the tape loads.the video heads are little black spec looking things on the bottom of the drum.the easiest way to clean the drum for a novice is to put isopropyl alcohol on a piece of 2 inch square paper.hold the paper very lightly against the drum with your right index finger.turn the drum from the top,anti clockwise.you will see some black stuff on the paper.do the same with a piece of dry paper.otherwise the tape will stick to the drum if still wet.DO NOT use a q tip,as it will get caught in the heads and break them.
sometimes,just running a new blank tape for 15minutes will dislodge the particles and the picture will re appear.if you have recently rented a movie,and saw lines running across the screen,and noise from inside the machine,it is damaged tape going across the heads and drum and it can wipe out the picture just like that.run a blank tape first and then clean the drum if you have to.
Jul 07, 2009 | Emerson EWD2202 DVD Player/VCR
Blank screen no picture
connection between the dvd output and screen has broke link somewere. pull it apart and check it out
Jun 05, 2009 | Philips Magnavox DVD/VCR Dual Player
Black Screen
If the LCD screen is not broken.the LCD backlight probably went out when it got dropped. Need to take it to a service center to get it looked at.
Mar 19, 2008 | Panasonic DVD-LS5 Portable DVD Player with...
Top portion of screen blank
could be down to the tube in side the tv that is what create the picture
Jan 14, 2008 | Panasonic PV-DF2035 20 in. TV/VCR/DVD...
Pinoeer DVD-366
Hi there, just got that progresive problem gone :D
- Startup ur DVD (ON)
- Wait until Loading - No Disc (status on DVD display)
- In here, ur screen still blank (black screen)
And here's how:
- Press "Home Menu" button
on ur DVD (it should be on the down left of the circle button)
-- Watch out, the screen still in blank, just feel it right ok?
- Down 2x -- Initial Setting
- Menu / Ok (the circle button)
- Down -- Video Out
- Menu / Ok
- Down -- Component Out
- Menu / Ok
- Down -- It will choose Interlace, it will saved the day :-)
- Menu / Ok
That's it.. Cheers mate ^^
Give me a mail if u still have the problem, coz I Know how it sucks.
Tyraxel@yahoo.com
Dec 02, 2007 | Pioneer DV-366K DVD Player
Problem with wacthind dvd in full screen and black dot on screen
Not sure I understand the half of the tv and half of the dvd player. Are you saying about mid way of your set is cut off and like the bottom half you have a picture and the top no picture? I can explain the dot, first you can open back of set and maybe take off hole back bezel. Get where you can put your head down in front of C R T's (tubes) and look down in them and see if you see the same thing in one or all three of the tubes. If so this explain the dot. The half problem sounds like vertical is missing. Not sure yet! Need feed back
Aug 10, 2007 | Philips 43PP9202 43" Rear Projection...
Icon F701WL 7 in. Car Monitor Logo
52 people viewed this question
Top Icon Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Dayton Computer
Dayton Computer
Are you an Icon Car Audio and Video Expert? Answer questions, earn points and help others
