Question about Singer CE-100 Futura Computerized Sewing Machine
Singer ce100 start button
Hi I have a singer futura ce100 and when I press the start buttin nothing happens. This thing worked fine until a couple of days ago and now nothing. In sewing mode the motor works fine and operates as normal. Now when I press the start button, nothing, no lights flashing, no beeping, just nothing. PLEASE help!
Vanessa
  • Anonymous Mar 25, 2014
    worked fine last night. today...beeps and all lights are flashing
Yes I am trying to use the embroidery unit when the start button won't work...it works up to the point of pressing start to embroider. The design is sent and ready to go.
Thanks Vanessa
Posted on Nov 04, 2008
    Scholar:
  • 110 Answers
Hi Vanessa,
Please give me more info in order to help you. Are you trying to use the embroidery unit? If yes, did you send a design to the machine via your computer?
  • Theo du Preez
    Theo du Preez Nov 06, 2008
    Hi Vanessa,
    OK, try the following.
    Switch off the machine
    Remove the embroidery unit.
    Switch on the machine.
    Push the embroidery unit into position. The unit should reset to lower left position and if already there attempt to go there. If there is no movement, your problem is technical one.
    If it does reset, select a design and send it to your machine, and remember to click on "send block" as well.
    Hope this help
I have a singer futura ce100. The Machine was working great. I changed my design and material, uploaded the design to the machine, the machine moved to the proper start position but when I pressed the...
You may want to try a different design. My best guess is a hardware problem. If you have a loose cable inside that would be the good news. Regardless you need to take this to an expert.
Jun 22, 2014 | Sewing Machines
My Singer Futura CE100 software will not work on my new computer with Windows 8. Singer does not have update yet. Any ideas on how I can get it to work. Thanks
My suggestion for now, have the earlier window version that you have been using for your CE100 also installed in your new computer.
Oct 13, 2013 | Singer CE-100 Futura Computerized Sewing...
Singer Futura CE100 will not work with windows 8. Singer has no solutions. Any ideas?
Suggest to also install the earlier windows version that can recognize your CE100 software into your computer.
Bought the upgrade for my Futura, I have a HP laptop with windows 7, I installed it according to directions and it tells me it failed to initialize security and will not even open up.
Number 1, go out to the Futura support site at www.Futura-support.com and download the patch for Windows 7. On the left hand side of the screen, click on Downloads, then CE100/150/250/350,etc, etc. Make sure you follow the directions CAREFULLY. Also, be sure to completely UNINSTALL all of the Futura software you've already installed and reboot your computer before starting all of the instructions.
If this gives you any problems, I've posted a solution under the CE100 solutions area for running your machine with Windows Vista/7 using a virtual machine program. It's a lot more steps than using the patch, but some people do still need to go this route. Look for it on the CE100 Solutions/Problems home page. Still, you should be fine just with the patch.
Happy embroidering!
Apr 22, 2011 | Singer CE-100 Futura Computerized Sewing...
I CAN'T GET WINDOWS SEVEN TO LOAD THE SOFTWARE COMPLETELY OR FIND THE DRIVER. IT GETS TO THE PLACE WHERE IT ASKS ME IF I WANT TO GO THROUGH THE TUTORIAL BUT THEN NOTHING HAPPENS. IT NEVER SAYS IT IS...
For old models CE100/200/200E Futura software could be upgraded to version 2.5 (ask you Singer supplier), since version 2.5.0.3 windows 7 is supported.
For newer models CE150/250/350 SES1000/2000 software can be updated normally, since version 3.0.0.9 windows 7 is supported.
Mar 29, 2010 | Singer CE-200 Quantum Futura Computerized...
How can i mirror image on the ce100, the directions in manual are not working. are there updates to capibilities?
As far as I remember there was no function "Flip hor./ver." in Futura 1.0.0.x. You could upgrade your software to version 2.5.0.x which is working with ce100/200 sewing machine models and contains functionality as newer models have. In this software version you will find function "Flip" in the context menu of Select mode (select design or color blocks you'd like to mirror, click right mouse button and select in the menu "Flip horizontally" or "Flip vertically").
Jan 31, 2010 | Singer CE-100 Futura Computerized Sewing...
Design is ready, when green light is pressed nothing happens
I have had good luck contacting the Singer peoplee themselves. Sometimes it takes a couple of days for them to respond. But, if that doesn't help try this.
Can you go forward a few stitches annd then start?
If not, try condensing your design by 1-2%. This was recommended to me by Singer when I had part of a design that wouldn't stitch out. It did the same as your whole design. I tend to think it is the digitizer, not the machine in my instance. Have you tried another design by a different digitizer?
Hope this helps.
Jul 19, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer Futura CE100 Connect Error. Check that USB cable is connected and power switch is turned on.
I received an email back from Singer stating that it is not possible at this time to load the Futura software on a 64-bit system using Vista. I have emailed to ask whether it would load if the OS were XP, but I haven't heard back yet.
They said that they were working on finding a fix for this, but they aren't sure that they will since it's a hardware problem.
Mar 02, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
224 people viewed this question
Top Singer Sewing Machines Experts
mystery_soul
Level 1 Expert
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
