Question about Maytag Neptune MAH5500B Front Load Washer
Neptune MAH5500BWQ Front Load Washer
Thanks for your input I thought about doing just what you indicated if I had a top loead washer, however, it is a front load washer and the door locks when the water is in it. Do you think it would hurt the machine and might it eventually empty of the beads if I were to find a away to run it through the rinse cycle repeatedly and then vacuum out any beads that remain in the tub until beads are no more? Trying to find a manual, since I misplaced mine somewhere, to see how to take the washer apart and vaccum it out may have to just call a repair person :(
  • Maytag Master
  • 5,568 Answers
Should have paid closer attention :-(
It still could float some of them if . . . you allow a partial fill, then pull the plug. One catch; it is possible that you cannot open the door with the plug pulled. It wouldn't be illogical that the maker would want to prevent serious spills in case someone opened the machine during a power outage.
If the beads are the same type of material from which disposable coffee cups are made (=soft) then it may not do any damage at all to the pump since it surely has to handle forgotten tissues and similar. However, because styrofoam is nearly eternal in lifespam when not exposed to UV, I would be a little reluctant to put that much in the sewer system or worse yet, a septic system.
Posted on Oct 27, 2008
Maytag neptune front load washer mah5500bwq ran a service cycle got these codes d 15 and 17 15. 17. What's this mean
Since repairing washers is a hobby and not a profession, I'm not familiar with that particular washer. I know that those codes usually mean it overfilled (D15) and the door lock failed to properly engage.
If you know what you are doing, you can check the switches with an ohm meter. Please don't do this if you aren't sure how to do this safely.
May 18, 2014 | Washing Machines
Tip
Maytag Neptune Front Load Washers No Spin Problem
A class suit was filed in the State of Illinois, USA and then later on won against Maytag in 2004 due to the high failure rate of the wax motor used in the door lock mechanism of their Neptune Front Load Washers. The wax motor is used to activate the door lock switch by extending its shaft when a voltage from the machine control is applied across its terminals. Its failure then leads to the breaking down of components in the expensive machine control board. This is the fact that angered the customers which led to the filing of the class suit.
The obvious symptom of a failed wax motor is the inability of the washer to advance to the spin cycle and the door lock lamp is not turned on. The washer stops momentarily at the end of the wash cycle then continue to tumble as the machine control checks the activation of the door lock switch. The control will not allow a spin speed higher than 51 revolutions per minute (RPM) unless the door lock switch is activated by the wax motor. It is a safety feature of the washer to prevent accident due to accidental opening of the washer door during a high speed spin.
Customers who purchased the Neptune Front Load Washers in the USA after April 1, 1997 and before August 9, 2004 are Class members and eligible for the repair reimbursement, replacement cost, or purchase certificate depending on the length of service of the machine. Call up Maytag at 1-888-MAYTAG (1-888-629824) for more information.
The models included in the class suit are as follows: MLE2000AYW, MLE2000AWW, MLE2000AZW, MLG2000AWW (Gas Stack Unit), MAH3000AAW, MAH3000AEW, MAH3000AGW, MAH3000AWA, MAH3000AWW, MAH3000BGW, MAH4000AWW, MAH4000BWW, MAH4000AWQ, MAH4000BWQ, MAH5500AWW, MAH5500BWW, MAH5500BWW, MAH5500BWQ, MAH55FLBWW, MAH55FLBWQ, MAH6500AWW, MAH6500AWQ, MAH7500AWW, MAH7500AWQ, MAH7550AAW, MAH7550AGW.
on May 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Door wont lock will not close properly
Cut and paste this factory service manual.
It will show how to access,test and replace all components.
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Jul 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer? makes a
more than likely it just needs a little leveling...lift front of washer . there are 2 leveling feet on each front corner under the washer.. they turn like a screw ..just adjust these feet till its level and you should be ok....shake the washer by hand . if it doesnt move it shoud be level,,,,an unlevel washer makes terrible noises ...as you know..thanks and have a great day
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Wash time too long
if the water supply is restricted, yes this would happen. remove supply hoses, check screens, check taps
Jul 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clogged screen on water intake.
it should just come out with a nice firm, but gentle pull. problem is u need to be careful because if its that clogged up, its probably weak and might break. U can always just buy new ones at sears, or home depot.
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Control board for Neptune top load washer has to be replaced.
Yes - the control board ECU needs replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 11, 2009 | Washing Machines
Neptune washer MAH5500BWQ
hi there,
looks like you have a leaky boot. you can purchase the part yourself at www.reliableparts.com
not sure about the labour to put it in, since i'm not sure where you live.
also, please supply the model # off your washer.
Sep 10, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load washer M#mah5500bwq
There have been problems with the motor wire harness connector on these washers. The problems are either a loose or bent terminal in the molex connector.
Unplug the connector and tug on each wire. If a wire comes loose from the plug, bend the locking tab up. If a locking tab is not properly seated in the plug connector, the terminals will not fully engage as the connector is plugged into the motor.
Another manifestation of this problem is that one of the terminals may be bent. Inspect the terminals on the motor side of the connector. Straighten any bent terminals if they exist. Recheck the harness side of the terminal block if any bent terminals are found. Bent terminals can indicate a problem with the locking tab inside the plug.
If this doesn't work then the motor control card is suspect.
Jan 02, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
145 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
