Question about AEG Lavamat 16810 Front Load Washer/Dryer
Aeg lavamat L 16850 leaking water seems to be coming from near top of machine
Leaking water seems to be coming from near top of machine error code EFO
SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Posted on Jun 15, 2009
SOURCE: my AEG lavamat 74620 doesnt fill up with water
I have the same problem but I think it is the Gears the orange cog goes up and the yellow than slips, clicking noise, I put some washers on top to hold them down more and the water is going in to the washer.
Posted on Nov 08, 2009
SOURCE: Anti-flooding system has activated.
Tip washing machine towards you, water in bottom of machine will pour out, so be ready! Should work after that, mine did!
Posted on Nov 18, 2009
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Posted on Feb 05, 2010
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
AEG Lavamat 16850 shows err (some kind of error code) anyone know how to restore to factory settings?
suggestion, ring up AEG and ask for the technical department
give them model and code and they should give you the answer your looking for good luck.
Oct 05, 2016 | AEG Washing Machines
What is error message efo
Filter is blocked, front bottom left open panel and clean filter but watch there is water in there,
May 17, 2014 | AEG Lavamat W1050 Front Load Washer
I have an AEG Lavamat 16850, only bought it 2 months ago. I have an EFO message and 3 beeps every minute. I have emptied the filter and it is a clean as a whistle and emptied the hose as well. I am not...
You have a leak in the machine and water is accumulating in the base pan. Most likely this leak is a manufacturing issue or a transportation issue. Check to see where the leak is coming from under the machine. If in warranty call the dealer.
Nov 15, 2017 | AEG Lavamat 12710 Front Load Washer /...
I have an AEG Lavamat L 16850. It has stopped showing an EFO error code for the second time (on the 20 minute cycle both times). The first time I removed the fluff filter which seemed to solve the...
We have this problem for nearly 2 years now. It always occured in a special program ("Kochwäsche/Buntwäsche 60°" what means coloureds/boiled 60°).
The AEG technician didn't find the problem. Since we avoided that program, the problem never occured again.
But now, close before 2-years-warranty-by-law I demanded them again to repair it. I will report.
Oct 25, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
How to deactivate EFO on Lavamat 76819?
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 03, 2010 | AEG Lavamat 74640 Front Load Washer
HI, The machine displays "EFO"... We put the water out as described on your site but it seems the code "EFO" is still in memory (there is no more water inside, but each time we start a new program, the...
Aug 15, 2010 | AEG Lavamat 88840 Front Load Washer
Tengo una lavadora aeg lavamat 72850 y me está dando error efo en la pantalla...las instrucciones me ponen que apague en aparato y llame al servicio técnico pero la garantia ya se me...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Aug 14, 2010 | AEG Lavamat 88840 Front Load Washer
How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Jul 17, 2010 | AEG Lavamat 74640 Front Load Washer
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
Jan 25, 2010 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
43 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
