Question about Toshiba CF32H40 32" TV
No picture...Sound is fine.
Toshiba CF32H40 is approximately 7-8 years old. No picture...black screen with good audio quality. Checked all cables/connections. Appears to be a fuse or tube. What is an estimate for repair? Recommendation for repair given cost or replace? Thanks...
    Problem Solver:
  • 4 Answers
Most likely : The Filiment CIRCUIT on the CRT board or a verticle problem, but first make sure all connected properly, then go ahead with the above???
Posted on Sep 03, 2006
    President:
  • 3,130 Answers
There are no tubes, except the picture tube, to replace.. itys a solid state set. your problem is most likly thefiliment circuiut on the crt board, or maybe a verticle problem. I would say with A set of this ventage, will most likly cost to repair more then the sets worth.
Posted on Aug 28, 2006
What can be done to repair picture to my TV
Vertical scan output section circuit should be checked. Contact any service technician.
Aug 30, 2014 | Toshiba CF32H40 32" TV
Toshiba CF32H40 32"TV shrinking picture with solid black on bottom. What causes this and can it be fixed?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Screen is black wiht a single 1/8 thick horizontal line across entire screen. Sound is ok. Other TVs are working.
cold solder in vertical ic and check caps around to..if you see resin around any cap, change.
Apr 22, 2010 | Toshiba CF32H40 32" TV
Toshiba Picture Not On
what you suggesting is that the lcd has a good maintenance needs that have to have cold solder or connectors are sulfated
Aug 22, 2009 | Televison & Video
No picture; black screen; only red light blinking.
take to a service station i think just changing the displsy IC would do . but check in service centre
Jun 19, 2009 | Toshiba CZ32V61 32" TV
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Problem with tv
Could be a horizontal output fault, faulty power supply, a simple dry solder joint or HVT. If you can hear arcing or smell an ozone odour, it will be the HVT which may cost a bit.
Without knowing the actual cause, it's impossible to say how much it would cost to fix it.... could be anywhere from $50 to $250 etc
Best to have it checked by a technician and get a quote to repair... then decide if you think it's worth it.
Toshiba is generally a reliable brand, so if you were happy with the picture quality before the fault occurred, it's probably worth repairing.
Cheers
Jan 05, 2008 | Toshiba 36A41 36" TV
Picture went black
The good thing is you see something in the screen,with age the set has developed loose conections in a few different places,my suggesion is to call professional for service now and the repair will not as expensive,if the picture quality is good is worth it.
Sep 22, 2006 | Sony KV-32V26 32" TV
Televison & Video Logo
189 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
