Lamp keeps burning out after 2 days. What could cause this problem.thanks
    Sergeant:
    Champion:
  • 227 Answers
Check your fans they probably full of dirt an running slow
good luck
caypianan@yahoo.com
Posted on Oct 27, 2008
My replacement bulbs keep burning out within 30 days. I took a closer look and there is a small square piece of glass that sits next to the lamp housing. It looks as if the light from the lamp goes through...
Something is definitely wrong if you are consistently only getting a month out of a bulb.
Either something is overdriveing the power to the bulb (unlikely) or there is a vibration or something is intruding on the bulb itself.
Good luck and let us know what you find on this.
Jan 08, 2015 | Mitsubishi WD-57732 Projection Television
I have a mitsubishi the model number is wd-82837 it keep shut down after blue screen show
Ur tv"LAMP"LED light indication flashes or stay on?Ur tv projection lamp been inside this tv like a 1 1/2 or 2 years and tv been on an in used like 4 or 5 hours every day.Yes to all of this,than the tv projection lamp is the causes and it life are ending.The tv projection lamp require replacing.
Dec 09, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Lamps keep going out. 4 since 2006
This is happening because the "Root Cause" is NOT being fixed, the "Lamp: is a SYMPTOM, NOT the "Cause". Replacing the Lamp is just spending good money after bad....Unfortunately there are quite a "Few" causes for it. If it has been done "Professionally" then they HAVEN''T done their job properly.
Feb 15, 2010 | Mitsubishi WD-57731 57" Projection HDTV
It keeps shutting off. Anywhere from 2 or 3 times
Could be several things. First replace lamp.Remove lamp door and put it back on making sure tab on door presses door switch downward when closed. Can you heard spinning noise from front. Bad color wheel will cause shutdown. Look at big cap on ballast . iff swollen replace lamp, ballast and power board. Is voltage to ballast from power board below 350 volts if so replace power board. hope this helps. Most common are lamp and door switch in up position rather than downward .
Nov 24, 2009 | Samsung HL-S5087W DLP TV
I have 2 'Madonna and child' standard lamps, whose halogen bulbs have all blown. Replaced them carefully - not touching the bulbs, but NONE of the lights work. Any ideas please? Thanks!
These could be low voltage lamps if so they have a transformer normally mounted in the base it sounds like this has blown not the lamps.
Another common cause is burning of the lamp holders especially if the lamps are wire ended..
HTH
Nov 13, 2009 | Kitchen Appliances - Others
TV Flashing colors
HEY WE HAVE A 72 INCH T.V AND IT KEEP POPPING UP DIFFERENT COLORS DURING T.V SHOWS WHY IS THAT WE JUST CHANGE THE LAMP IN THE T.V CAUSE IT HAD WENT OUT ON ME AND THAT WAS ABOUT 1YEAR AGO FROM MARCH13,2009 SO I WAS WOUNDING WHAT CAN WE DO OR ANYONE SAY EVEN IF IT IS THE LAMP CAUSE WE ARE STILL NOT SURE!!! THANK YOU E-MAIL ADDRESS IS bianca_guero_0909@doglover.com
Aug 01, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Infrequent use of Xerox Phaser 8500
The reason he told you that is because ;
if left on permanently the fuser unit has a lamp ( nowadays the newer ones use a ceramic) the lamp continually comes on to keep the fuser warm and ready for you to print.which may cause the lamp to burn prematurely, most business keep theirs on all day with out the sleep mode( too busy to wait to warm up),
But, when you use the sleep mode most models do not turn on the lamp ( if it does it only puts out minimal power) but keep the power ready, which is why when you go to print it takes awhile to warm up.
The lamps are very resilient and last several years before having to change.
Jul 17, 2008 | Xerox Phaser 8500/DN Printer
Lamp keeps burning out. I have had the tv 2 years. The original lamp burned out in 1 year. I have since replaced the lamp at least 3 more times in the following year. Help!
Hi.
Im not at all familiar with your sony model but I do know that when A lamp is replaced you must reset the lamp timer if it is not reset it will cause premature lamp failure.
This is normally in the engineers menu as I said I dont know your model its not one I recognise so im sorry but I cant tell you how to enter service mode.
Hopefully one of the techs on here will know how and help you.
http://dysonmanuals.inc.io/
Chris.
Nov 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
WD-52525 Lamp failed 2x in 4 months..is it the Lamp?
do you get an error code? hold the MENU and DEVICE buttons when turning on the TV and get error code
Oct 20, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
