Question about DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker
De longhi, esam5500, heating up
It says constantly, heating up, please wait... Everything including the infuser has been cleaned and lime scaling done. It worked well for weeks.
3 Suggested Answers
SOURCE: insert infuser assembly alarm on De longhi coffeemachine
Did you try tightening the 2 hex screws behind the infuser?
Be gentle though. Mine felt tightend but thenIput just a bit more pessue on them and got an eigth to a quarter more turn out of them. Found this solution on this site
Posted on Sep 07, 2010
SOURCE: Unable to remove the infuser
Hopefully you've solved the problem by now, if not:
I had the same issue and assumed that 'Turning the appliance off' ment turning the main switch off behind the unit. This is not the case. Just turn off the unit using the button on the top left of the facier panel. I then found that the pressing in of the 2 red button allowed the infuser to slide out easily.
Posted on Feb 08, 2011
General warning coming up in heating cycle.Not working at all.
For DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Team De-Brewerz.com says:
1. General Alarms should be taken care by authorised delonghi technician only. Please do not try to fix yourself as it is related to safety.
2. This error occures due to loose wirings, opened water circuit, failure of heating elements and last failure of PC board repalcement.
3. Please contact your nearest Delonghi authorised dealer for technical support.
4. You can claim the warranty if recently purchased through De-Brewerz.com . If you are in India then contact us at de.brewerz@gmail.com
Nov 03, 2014 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Iron cleaning
Have you been using distilled water?
If you haven't, then inside the iron could be calcified - lime scale.
You can buy a chemical, made for the job. to de-scale irons. This would be worth a try before buying a new one.
Good luck.
May 05, 2014 | Euro-Pro Upright Steam Mop - Metallic...
HOW TO RESET CODE 1L
Open cover.. find buttons min/max press nim then press mas and then hold min and max presses for 5 seconds or so. Power off controller and power back on..You have reset your fault code til next time. Rheem is poor on info and poorer yet on service..Good luck
Aug 04, 2011 | Rheem Tankless Hot Water Heater...
Yesterday and today the machine did not come on as normal it said press next + change, nyesterday when I did that it said generic alarm, but then worked, today the generic alarm would not go off. the book...
I had the same problem with the infuser stuck at the top and the triangle light staying lit. I fixed it by unplugging it from the wall. I then removed the side panel and the back panel.
Facing the rear move the sprocket that the motor drives. The best way to start it (if it is stuck) is with a flat screen driver on the right side of the motor and push the sprocket towards the front. Once it starts you can either pull the belt from the other side or push it from the right side. It took 10 minutes to get the infuser to completely come down.
After that I pulled it out and cleaned everything. When I put everything back together the light stayed on and the machine would not respond. I did fix it by turning on the machine, pulled the power plug, and when I plugged it back in the system went through its cycle. Everything is fine now.
Jun 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Flashes il
Before calling service technician, open following link for Rheem tankless resources including error codes and possible manual.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Read your manual for troubleshooting, advisories and required maintenance.
Tankless are maintenance heavy.
1L means tankless heat exchanger has lime build-up.
De-lime tankless unit.
U-tube has videos for de-liming tankless, but there is more to consider:
De-liming is yearly maintenance requirement.
Tankless are prone to lime build-up
Regular de-liming will not restore full efficiency to tankless unit.
Tankless cannot be exposed to water with more than 11 grains hardness.
Temperatures over 135 can cause minerals in water to harden on metal surfaces of any water heater.
Also clean Tankless water filter each month, and clean and maintain burner and combustion chamber yearly.
The cost of maintenance and cost of expected repairs and cost of parts plus cost of original installation will never pay back the $1-8 monthly savings on gas bill. All costs are energy.
Make sure there is qualified service technician in area before buying tankless.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 24, 2011 | Rheem Tankless Hot Water Heater...
De-scale message appeared. Followed instructions in manual. Product not working. Everything smells like vinegar. Now what???
Sorry to read about your issue.
you should have done whats below, it may need to be done twice...last but not least..you have to put more fresh water in to remove the taste
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 23, 2010 | Keurig Platinum B70 Coffee Maker
Insert infuser assembly alarm on De longhi coffeemachine
Jan 15, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Logo
55 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
