Question about Home
Tub heater kicking out
I have a 110 Jacuzzi brand 250 gallon hot tub and I get a
blinking light I think indicating it is overheating and this
stays on. No controls will work. The heating element is
good and I removed the filter to see if that was restricting
things with no change. The only way to jog it out of this
mode is to open the cover and let it slam down and it will
start heating again. If I go through the modes again jets,
light,and heat it will kick out again and I have to slam the
lid. I have tried to tap the thermostat and other
components individually but only slamming the lid resets the
tub. It worked great for 10 years before this problem. Any
idea what the problem is.
I also found another way to reset the pump so it heats and circulates. There are a black and a red wire going from the top right corner of the control panel to a sensor that sits on the heating element housing. tapping the element did nothing but disconnecting it at the control panel or at the sensor and re-connecting it resets the heater. I also disconnucted the thermostar wire which uses a phone cord type conection in the controle pannel which did not reset the heater.
Thanks Gavin
  • 125 Answers
Sounds like a part is bad on the control pack. Whatever gets 'jiggled' when you slam the door down is most likely the bad part.
Posted on Feb 24, 2009
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Jacuzzi hot tub will not reach temp pumps do run?
If your hot tub is running but NOT heating then you need to look at a couple of things.
First, on the topside, is the heat indicator light on?
If it is on and the tub is not heating then the temp sensor or the high limit sensor is not working and need to be replaced.
US Parts Center
Oct 22, 2013 | Jacuzzi Home
Jacuzzi z112
What is the problem you afe having with your Jacuzzi Water Heater?
Is this a Jacuzzi Hot Tub?-- Do you have some indicator lights on?-- what color are the lights?--
Is the Circulating pump running water thru the heater element?
Tell me more!-- Let's walk thru the system, and figure it out-- Mack B
Oct 13, 2013 | Water Heaters
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
My electric went out for 24 hours. I hooked up my generator to the breaker box to power the house. The generator only powers one 110 leg so there would have been 110 going to oneside of the 220 breaker to...
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Dec 13, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Overheating problem
It sounds like the problem is in the main control box. Since the tub shuts down after reaching 110 degrees, the high temp sensor is doing its job. This sounds like a job for a qualified professional. Do get a price for the service call as they are usually expensive. Circuit boards start at 200.00 and go up.
Sep 15, 2009 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
Need a users manual
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Nov 11, 2008 | Balboa Instruments Garden
Jacuzzi Hot Water Heating Capacity
Depending on how you heat the hot water, whether gas or electric, is a missing detail in your problem, but if it is electric then your problem is the size, being only 40 gal, and needing probably about that to fill the tub, will always lead to your current position.
If the hot water heater is gas, the chances of it keeping up are slightly better, but again things like the temperature of the water leaving the tank, any mixing valves, etc. will effect the water temp at your tub.  Before raising any temps, make sure you follow local code, as not to scald yourself or others.
Sep 28, 2008 | Home
Home Logo
162 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
