Question about Vizio L32 32 in. LCD HDTV
32" visio tv tripping power throughout the house
I have replaced the circuit breaker and power strip supply, checked the plug, (checks out Ok), why is TV tripping power in house?
    Scholar:
  • 70 Answers
I would have an electrician check to see if you have a grounding issue. Especially at the outlet that you have the power strip supply plugged in, Check to see what kind of your circuit panel is going to trip for electrical arc or electrical short. Newer panels should have both. Older just for electrical short. Have your electrician make sure your wiring is entirely copper, if it isn't and it's aluminum. Have him make sure the outlets are aluminum rated, and not designed for copper. Defintely check grounding. Good Luck
Posted on Oct 27, 2008
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Sep 05, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Roper model rex5634kq1----won't get hot---already removed &ck'd heating element & attached part (thermostat?)--they're both ok--what else could it be?
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Dryers
No heat, seems to be continuity for heating element
Firstly, make sure you have selected/ascertained a heat setting, then read on from the checklist below, supplied by; www.repairclinic.com
Heating element
Thermal fuse
Wiring
Jul 07, 2009 | Maytag Dryers
My HP HDTV trips my circuit brakers
1) Try with a different surge protector. The oine you're using could have a short-circuit
2) Try without a surge suppressor, at least for a day
3) Does the circuit breaker trip when something else starts running? Your microwave, fridge, dishwasher, etc.?
4) Check the user's manual of your TV, under SPECIFICATIONS. Check for "POWER REQUIREMENTS". If the power requirements listed is greater than 15 Amps or 1,700 Watts (assuming you live in the USA and your household is 110-120V), then the circuit breaker will almost always be triggered by the TV. Most circuit breakers inside a house are 15 Amps.
The only option you have is to replace the circuit breaker for one that has more Amps, but doing so on your own without having and electrican check if the wiring will hold the extra load is extremely unadvaisable. You may end up with an electric fire in your hands.
May 29, 2009 | HP PL4260N 42 in. Plasma HDTV
Dryer will run in cool down mode,but not in any other.
Hi!
Please check the following---
Heating element
Thermal fuse
Wiring
Please accept this solution and ask for any clarification.
Thanks
Rylee
Mar 22, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Powercom BNT 1500AP quit working after power outage
From your description it appears one or more batteries are bad..The circuit breaker on the Power Strip..which more then likely is a 15 Amp..tripped due to over current conditions..check the batteries and reset the circuit breaker..That should take care of it
Dec 28, 2008 | Powercom (BNT-1500AP) UPS System
Lcd television trips circuit breaker when plugged in to wall outlet. Problem started yesterday after wall mounting the unit.. Removed wall mount and it still happens (worked fine before wall mounting...
I would check 2 things. If the TV trips another breaker in the house of the same rating, you probably have a short in your TV and will need to have it serviced.(You didn't drop it did you? :-) ) The short may also occur by too much stress on the power cord where it enters the TV, common to need to cram the cord into small spaces when wall mounting. If the TV only trips that particular breaker, I would try replacing the breaker. Replacing the breaker costs very little and will only take you a few minutes. You can buy a replacement breaker at most hardware stores. Just make sure to disconnect the main supply first! Also, make sure the breaker is rated correctly, using a higher amperage breaker will increase your chances of starting a fire.
May 05, 2008 | Televison & Video
My TV does not turn on I have a Mitszubushi 60 Inch
The first thing to do is check the outlet that it is plugged into.
Do you have a gfci outlet that may have tripped?
Sometimes the whole circuit that the tv happens to be plugged into may have tripped at the electric panel.
Chek for a blown fuse or tripped circuit breaker.
If that is ok, check inside the tv for a blown fuse close to where the power cord is attached.
If still no power, then it will take a checking of the power supply/power circuit board, which may be something a service person should check into.
Apr 08, 2008 | Televison & Video
Vizio L32 32 in. LCD HDTV Logo
252 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
