Question about Panasonic NN-T993SF Microwave Oven
Fuse Cant find any info on how to check or change the fuse.
  • Anonymous Jun 16, 2008
    looks like a brown fuse with brass end. doesn't pull out. now what?
    President:
  • 878 Answers
Agrivated, looks like the fuse 18amp is in the back on top. You will have to remove the shell off the microwave to get at it. This one operates with a inverter..you have some high voltage there. Make sure it's unplugged. While you have it apart, check the primary switch, top one on door latch. If the monitor switch finds this closed when the door is opened it will blow that fuse. You also have a cavity thermal cut out that will shut the oven down. Catriver...post back.
Posted on Aug 28, 2006
GE microwave oven fuse? no sign of power
PokMan, Check the attached links,instruction and guides on fuses and thermal fuse breaker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Where is the fuse located and how do you replace it GE Microwave Oven
GE Microwave Fuse Thermal Fuse Breaker Parts
GE Microwave Oven internal fuse Google Search
Microwave Not Working
Microwave Oven Troubleshooting in MINUTES STEP BY STEP
Jun 11, 2016 | GE Microwave Ovens
Does this unit itself have fuses inside it? If so, how do I access them.
Shelia, A lot of microwaves do have internal fuses, Links below will show how to change them.
How to Fix Microwave Oven Simple Fuse Replacement
Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
Microwave Line Fuse Replacement Whirlpool Microwave Repair Part W10422951
Mar 21, 2016 | Microwave Ovens
Oven went dark. changed two glass fuses and everything works but oven doesn't heat anything
A bit more info? BRAND? MODEL? AGE?
Sounds like the Magnetron might done. Checked the Thermal fuse? (should reset)
Nov 29, 2014 | Microwave Ovens
Interior light bulb burned out previously; now no power at all.
I have had to change the fuse in a handful of my microwaves,usually when they get to be about 10 years old.If you take the housing off,you should find an inline fuse holder on the power cord just as it enters the housing.Read the info on the fuse,and replace it with the same size/type(the ones I've seen are ceramic fast acting fuses)I also like to take another spare and tape it inside the housing near the fuse holder so I don't lose the spare.
Jan 01, 2012 | Magic Chef Jade Microwave Ovens
Is there a power fuse on a MCD1611?
Yess there is a ceramic 20 amp 250 volt fuse inside the cabinet. Safety first!!! Unplug the microwave from the wall outlet.
If you remove the four T20 Torx screws that hold the case on(back of cabinet around the edges) and carefully slide the case back and up you can access the fuse. It will be on the circuit board near where the power cord enters. If you have a ohmeter you can check the fuse. The ceramic fuses are not clear so you cant tell a blown fuse by looking.
Feb 16, 2010 | Magic Chef MCD1611 Microwave Oven
As i turn on microwave it blows the fuse. what could be the reason.
try using it at a different location in the house(different circuit) if it also blows that fuse, there must be a short in the unit. do not use. if it works means line in the kitchen is overload, and you need a higher fuse rating or breaker.
Sep 10, 2009 | Microwave Ovens
Makes a loud humming sound and blows fuse behind controll panel
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix.
Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
Sep 02, 2008 | Sharp R-1460 Microwave Oven
Delonghi combi microwave
It may be the internal fuse, or the thermal fuse / thermostat / thermal cutout on the magnetron. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 27, 2007 | Microwave Ovens
GE Space Maver MIcrowave
If it blows the fuse as soon as you hit START, you probably have a high voltage capacitor shorting. If it blows a fews secondfs after you press START it probably has a bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 You might also double-check the magnetron. The technical sheet inside the oven shows you how to check it.
May 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-T993SF Microwave Oven Logo
207 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
