No hot water is coming inside the washer machine samsung WA90F3
There is no hot water coming inside the washer machine
  • 26 Answers
SOURCE: No hot water into washer
In your problem you describe that you are getting hot water are you getting cold water too?. Make sure on the water valves are on the full open setting to eliminate a water pressure diffrence and any other valves connected to those water lines. If that checks out check for clogs in the hoses and filters that could be backed up. If that dosent fix the problem then its in the washer either the hot/ cold regulators or the timer.
This is for GE WBSR3140DW Top Load Washer
Heres a link to help to find the correct parts.
http://www.partstore.com/Model/General+Electric/General+Electric/WBSR3140DW.aspx
Hope this info helps to anyone who reads it.
Posted on Feb 25, 2009
SOURCE: Only hot water is coming through the washing machine
make sure the hose is not plugged,and if you have hard water claen the skreen,i had the same problem the skreen was plugged.
Posted on Mar 01, 2009
ginko
  • 19396 Answers
SOURCE: ty for being here. I have a kenmore stack washer
Inside the machine you have a valve called inlet.
The inlet water valve will collect the cold and hot water lines, and open alternatively one or the other during cycle.
To access the inlet valve you need to take apart the machine, and that is not an easy task.
If you DIY remember to unplug power, there is high voltage running inside your appliance.
Below the inlet valve for your model:
1014350
Posted on Mar 05, 2009
mgprice
  • 744 Answers
SOURCE: NO HOT WATER MAYTAG WASHER Model # LAT9706AAE
replace the dual inlet valve located in the rear of the machine. have included a link to help you...you can also purchase the part from the same link. http://www.partselect.com/repair.aspx?appliance=washer&part=replace-water-valve
Posted on Jun 23, 2009
techbuster
  • 5081 Answers
SOURCE: HELLO !
ya u can use no prob
Posted on Jul 03, 2009
Samsung front load washer will turn on but will not let water in to start wash cycle.
the humming sound is the coil for the solenoid that activates the water valve
have an technician replace it or if you are not using hot water ,change the hoses at the taps and use a hot water setting
Mar 25, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
No hot water
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
  • Is the hot water turned on? If not, turn it on.
  • Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.
  • Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
  • Sep 21, 2008 | Hotpoint VBXR1090D Top Load Washer
    Whirlpool washing machine does not rinse just a buzzing noise
    The buzzing is the water valve, the timer is sending power to the valve but no water is coming out. I would set to wash and as it is filling up change the water to cold then to hot while it's filling. I bet either cold or hot will buzz (usually hot). Once you determine which (clod or hot) shut that supply off, take that water line off the washer, put the end in the washer and turn the supply back on. If water comes out then look inside the valve where the hose connects, it could be clogged. If you have water going to the valve and you don't see a clog then the problem is inside the valve...replace valve.
    Oct 21, 2014 | Whirlpool Washing Machines
    Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
    Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
    Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
    Hot water keeps filling tub and does not quit
    the washing machine is designed with a timer limit switch have the switch checked.
    Oct 19, 2012 | Samsung WF448AAW 4.5 cu. ft. Front Load...
    My washer will only use the hot water
    1. First, make sure that your cold water valve, behind the washing machine, is turned on, and water is coming out.
    2. If there is water coming from the cold water valve, this water goes to another valve inside of the washing machine. Open your washing machine and take out the Diagnosis Manual (usually found in the top portion of the machine with the computer boards, or on the back panel)
    3. Diagnose the Water Inlet Valves per the instructions in the Manual.
    Jul 15, 2010 | GE WSXH208A Front Load Washer
    Bad smell from washer despite wiping down insides with hot soapy water
    Try a hot wash with recommended dose of soap (no garments).
    Fabric softener can build up inside a washer over time, particularly if quantity of soap used is less than suggested on packet.
    Mar 12, 2010 | Samsung Washing Machines
    Samsung Washer,less than year old. Not every load and not every item but periodically something will come out with stains not previously on the item.
    This is common, if the machine does predominantly COLD washes.
    Over a period of time, there is a build up of soap scum (washing powder/fabric softener etc) inside the machine, caused by using excess soap powder/detergent.
    To recitfy this, fill the empty bowl (no clothes) with a solution of HOT water & CITRIC ACID (found in the baking isle of your grocery shop) on HI Water level. Set the machine to wash cycle, then drain.
    Fill again with same solution, but leave solution inside the bowl overnight.
    Drain next day, then follow with 1 single HOT wash (no clothes) on HI water level again.
    The scum should be gone...
    The hot flush should be done at least every 6 months, but this can be dramatically reduced if you use less soap powder (Samsung machines do not require as much powder, as do other machines)
    "If this has helped you, please rate this solution"
    Nov 29, 2009 | Samsung Washing Machines
    Ty for being here. I have a kenmore stack washer
    1014350
    Mar 05, 2009 | Kenmore Washing Machines
    Washing Machines Logo
    18 people viewed this question
    Top Washing Machines Experts
