Question about Dryers
Frigidaire Dryer blower wheel will not screw onto motor shaft properly
I have a Frigidaire Dryer model FER341AC0 and just bought a new blower assembly for it. The blower assembly has a metal piece in the center that is half threaded. This will not fit onto my motor shaft properly. I ordered the blower assembly based off my dryer model number, so it should be the correct part. Why will the blower wheel not screw onto the shaft all the way? The shaft isn't even threaded. It appears that the metal piece is prevent the wheel from completely fitting onto the motor shaft, almost as if its not the correct part. But, I couldn't find another blower assembly for this particular model. What gives?
  • 65 Answers
SOURCE: Can't remove dryer blower wheel
I would start by taking off the top and checking the belt to see if part of it tore and is hitting the inside of the cabinet. I have not found a real good way to get the blowers out without having to break them sometimes. the part of the blower that you have to hold is access through the front behind the motor. problem is when you turn the motor shaft, the wrench strips out on the blower, then you have to break them, but unless you need a new motor, it should not have to come off.
Posted on Jan 27, 2009
SOURCE: fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Posted on Mar 10, 2009
  • 686 Answers
SOURCE: Blower wheel loose on shaft of motor on maytag dryer
GO TO www.repairclinic.com and enter the model number look for your blower wheel item 1245880 it looks as if there is a flat side on it. this may help ya Good luck
Posted on Apr 10, 2009
  • 659 Answers
SOURCE: Trying to remove drum and how to check heating
You don't have to remove the drum to get to the heating element. Remove the cover at the bottom of the dryer, it should be on the right at the bottom.
Posted on Apr 11, 2009
emissionwiz
  • 76846 Answers
SOURCE: where is the heating element in a frigidaire dryer
indise the drier cabinet
Posted on Sep 18, 2009
Goodman model # AWB2405D
Turn off your power, remover both the upper and lower doors. You may have to disconnect some ''molex' plug connectors and you may have to remove some thermostat wires to gain access. If you remove any wires, WRITE them down as to what terminals they go back on. The molded plugs can only go on one way so don't be too concerned about their replacement UNLESS they are individual plastic plug ins for each wire. If so...WRITE down the location and proceed.
There should be either 5/16" or 1/4" headed screws securing the blower assembly in place. The assembly itself is probably slid into position on sheet metal rails or into slots. When the proper two (usually) screws are removed, it will merely slide out the front of the furnace.
Place it on the ground and look into the side of the assembly OPPOSITE of the motor. In there you will find a 5/16" square headed set screw. Remove that screw because it secures the blower wheel to the blower motor shaft. Clean rust, dirt and debris off the exposed shaft because that will inhibit the sliding of the shaft OUT of the wheels hub. Turn it over to the motor side up. There will be three bolts or scews securing the blower motor to the blower housing by means of a three legged 'spyder' mount. Remove them and work the motor and shaft OUT OF the blower wheel hub.
You are now home free... the motor is removed. Reinstall in basically reverse of the removal procedure. Hopefully you have an IDENTICAL replacement, so there will be no wiring adaptions to figure out.
May 16, 2014 | Goodman GMS90703BXA Heater
DRYER DOES NOT START ONLY MAKES BUZZER SOUND. WHEN YOU ROLL AROUND DRUM WHEN PUSHING BUTTON IT STARTS. IS THERE A MOTOR STARTING CAPACITOR OR DOSE IT SOUND LIKE NEEDS NEW MOTOR. MODEL NVLR223EH1WO
sounds like a motor these Do not use a starting capacitor, they use very small Gage wire for the start windings ..You can get a new motor for about 130.00 dollars if you decide to replace it I would advise you to also order a new blower wheel ,, after time the blower wheel has a way of seizing its self onto the motor drive shaft and 90% of the time you have to destroy the blower wheel to get it off it adds about 25.00 to 30.00 more to the job but you will be glad you did
Nov 23, 2010 | Hotpoint NVL333EY Electric Dryer
Need to replace heater blower motor. How do I get to it?
Behind the glove box. Please see my tip at http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow . These are generic instructions. If you get stuck, please get back to me.
See instructions from autozone.com below.
REMOVAL & INSTALLATION
With Air Conditioning
See Figures 1, 2 and 3
  1. Disconnect the negative battery cable.
  2. Remove the glove compartment door and glove compartment.
  3. Disconnect the blower motor wires from the blower motor resistor.
Fig. Fig. 1: Disconnect the blower motor wires from the blower motor resistor-1988 Escort
  1. Loosen the instrument panel at the lower right-hand side prior to removing the motor through the glove compartment opening.
  2. Remove the blower motor and mounting plate from the evaporator case.
  3. Rotate the motor until the mounting plate flat clears the edge of the glove compartment opening and remove the motor.
  4. Remove the hub clamp spring from the blower wheel hub. Then remove the blower wheel from the motor shaft.
Fig. Fig. 2: Unbolt the mounting plate from the case
Fig. Fig. 3: The motor can now be removed from the case
To install:
  1. If removed, assemble the blower wheel to the motor shaft and install the hub clamp.
  2. Install the motor and blower wheel assembly.
  3. Secure the instrument panel at the lower right-hand side.
  4. Connect the blower motor wires at the blower motor resistor.
  5. Install the glove compartment door and the glove compartment.
  6. Connect the negative battery cable.
  7. Check the system for proper operation.
Without Air Conditioning
  2. Remove the air inlet duct assembly.
  3. Remove the hub clamp spring from the blower wheel hub. Pull the blower wheel from the blower motor shaft.
  4. Remove the blower motor flange attaching screws located inside the blower housing.
  5. Pull the blower motor out from the blower housing (heater case) and disconnect the blower motor wires from the motor.
To install:
  1. Connect the wires to the blower motor and position the motor in the blower housing.
  2. Install the blower motor attaching screws.
  3. Position the blower wheel on the motor shaft and install the hub clamp spring.
  4. Install the air inlet duct assembly and the right ventilator assembly.
  5. Connect negative battery cable.
  6. Check the system for proper operation.
Nov 05, 2010 | 1989 Ford Escort
Cannot find heater blower in 1999 ford taurus
It's hiding deep behind the right side dash. See instructions from autozone.com below.
1997-99 Models
  2. Disengage the instrument panel insulator from the instrument panel.
  3. Detach the wiring connector at the blower motor.
  4. Unsnap the instrument panel upper finish panel from the instrument panel.
  5. On vehicles equipped with autolamp, Detach the electrical connector from the light sensor amplifier.
  6. Unsnap and remove the instrument panel finish end panel from the right side of the instrument panel.
  7. Remove the 3 screws retaining the instrument panel to the upper cowl top panel.
  8. Remove the 2 screws at each right side of the instrument panel.
  9. Remove the 3 screws retaining the blower motor to the evaporator housing.
  10. Pull the instrument panel away from the cowl and remove the blower motor from the A/C evaporator housing.
  11. If required, separate the blower motor wheel from the blower motor by removing the retainer from the blower motor shaft and sliding the blower motor wheel off the blower motor shaft.
To install:
  1. If the blower motor wheel was removed, align the flats on the inside diameter of the wheel hub with the flat surface on the blower motor shaft and slide the blower motor wheel onto the blower motor shaft. Install a new blower motor wheel retainer onto the shaft.
  2. Install the blower motor and wheel assembly into the evaporator housing and firmly tighten the 3 retaining screws.
  3. Reposition the instrument panel and install the 2 screws at each right side of the instrument panel.
  4. Install the 3 screws retaining the instrument panel to the upper cowl top panel.
  5. Install the instrument panel finish end panel to the right side of the instrument panel.
  6. On vehicles equipped with autolamp, Attach the electrical connector to the light sensor amplifier.
  7. Snap the instrument panel upper finish panel to the instrument panel.
  8. Attach the wiring connector at the blower motor.
  9. Engage the instrument panel insulator to the instrument panel.
  10. Connect the negative battery cable. Check for proper blower motor operation.
Nov 01, 2010 | 1999 Ford Taurus
Motor heats up and stops running how do remove
The blower fan on this model has reverse threads where it screws onto the motor shaft. At the small space between the motor and the rear wall of dryer you will see that the blower wheel has a square neck that will allow you to hold it stationary with a large crescent wrench. while holding the blower grip the pulley on the front of the motor with another wrench (or channel locks) and turn the motor shaft clockwise to break the blower loose. Sometimes a quick motion is better to free it as it may be on the motor threads pretty tight.
Good luck on this!
Jul 11, 2010 | Whirlpool LER7646E Dryer
How to install a front blower motor in a 96 ford explorer
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
Apr 23, 2010 | 1996 Ford Explorer
Dryer vibrating with overheating smell
The vibrating is usually the blower wheel not being balanced or worn and not spinning, therefore it does not blow enough air and therefore the system overheats-----and so, the smell. Some models need to be serviced from the rear, others need to have the front face removed to access the blower wheel assembly. The blower wheel is approx. $25 part but you need the skill to access and replace it properly. Goodluck, Macgivor
Dec 27, 2009 | Frigidaire Dryers
The blower fan is loose and jumps alaround but I seeno way of securing it the is just a grease fitting there
The blower wheel tightens to the motor shaft(reverse threads) and the housing to the casing. if unable to tighten to motor, could be a broken blower wheel...sold as assembly part#131775600 sugg retail$50.(includes housing and wheel)
Jun 10, 2009 | Frigidaire GLER331A Electric Dryer
Apr 09, 2009 | Dryers
Vibrations when drying
Unplug the dryer.
Take a putty knife and push the clips in between the front panel and the top lid.
Raise the top back, out of the way.
Inside the right and keft front sides of the front panel, remove the 2 screws.
Remove the wire connector to the front door.
Set the front panel aside.
Remove the screws from the blower wheel cover on the bottom left and check the blower wheel for free play on the motor shaft.
If free play is there, replace the blower wheel.
Reach underneath the drum and remove the belt from the motor pulley.
Lift the drum(it will take some force) by pulling the rear of the drum up.
Then pull it out.
The drum support is attached to the rear of the drum. The drum catch is mounted at the rear of the cabinet and is U shaped.
Replace both these parts.
Re-assemble and run your dryer.
Apr 05, 2009 | Frigidaire FDG546RE Dryer
Dryers Logo
57 people viewed this question
Top Dryers Experts
