Question about Dishwashers
How do I unlock the child proof switch on a dishlex global 300
The dishwasher is locked
SOURCE: Dishlex Global 300 Dishwasher
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
Posted on Sep 15, 2008
SOURCE: Dishlex global 300 dishwasher, eco
Try taking the dishwasher out of its wall space and tipping it back and forth. Apparently the weight of water gathering in some component triggers the 'eco' function. Failing that, last time it happened to my dishwasher i waited a week for the repair guy to arrive, by which time the water had evaporated and there was no longer a problem..
Posted on Jan 09, 2009
SOURCE: Dishlex Global 300 - stopping mid cycle
This is just a suggestion....  so please try and please post any corrections.
Anthony M is on the right track.  Refer to his entry and download the manuals. Tks Anthony.  When the Dishlex 300 starts for the first time, there is a service mode set up. The service mode allows you to set a 'fill-time' for the water to reach the right level, dependent on the water pressure and flow... which is described in the manual.  So resetting the Dishlex is the first step. Then set the water level.  If the water is too low, it will not wash, it will flash. When the water is too high, it will leak out of the rubber seal.
I hope this helps you all. Waz
Posted on Jan 14, 2009
This problem is common to both the 300 & 310 models. The flashing Fast light indicates a blockage in the water supply. I fixed this by:
- disconnecting the dishwasher
- checking for blockages in the input hose filter (there were none)
- removing the bottom of the dishwasher (two screws at the front)
- looking for the translucent plastic bucket thing attached to the side of the main assembly
- unclipping it from the main assembly and removing the white hose attached to it
- flushing 5 years worth of evil gunk down the sink (you need a small brush or piece of wire to get it out
Gabriel
Posted on Jul 28, 2009
jyackle5
  • 8197 Answers
SOURCE: child proof lock light is on, cannot run the dishwasher
To turn off the Child Lock
Press and hold ENERGY SAVER DRY for 4 seconds. The
light turns off.
Posted on Apr 18, 2010
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Child proof lock light is on, cannot run the dishwasher
light turns off.
Apr 18, 2010 | KitchenAid 24 in. KUDM25SH Built-in...
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Global 300 Dishlex draining problem
is the float switch clear of debris so it can go down to its lowest point to shut off the pump,, a peice of food could be stuck in it, keeping it up just enough to keep it running
Jan 03, 2009 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishlex global 300
try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
Feb 04, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
