Question about AEG Washing Machines
Aeg lavamat error code E20. Machine will not progress to spin cycle
    New Friend:
This means that there is an issue with pumping water out from the machine.
Possible reasons:
-The hose for water outlet is bent
-The water outlet is more than 1metre above the bottom of the machine.
-The emptying pump is clogged up
-If connected to a waterlock, the waterlock may be clogged up.
If the emptying pump is clogged up, the solution is to empty the machine manually. First turn the machine off and disconnect the electricity. There is a small lid on the bottom right corner of the machine. Inside you will find a small hose. Ready a small box for collecting the water. Warning: The water may be hot. Allow the water some time to cool down. Remove the plug from the hose (screw it out at first, then pull the rest out). You may have to empty it in a couple of sessions. Just put the plug back in if the box gets full of water. repeat until no more water flows out. Put the plug back in. Now put a towel underneath the front of the machine for collecting water that flows out when you open the lid for the pump. You can open the lid of the emptying pump by turning it counter clockwise. It is right next to the small hose you just used. Pull the lid out, and remove what is clogging up the pump. Before you slide the lid back in, you should check that the pump goes around. You can do this with a pen and a flashlight. Use the pen to move the pump around. It is normal for it to move in "bursts" (that it's not revolving smoothly). Slide the lid back into the tracks on the inside of the housing of the pump, and close it. Now you may reconnect the electricity, and the machine should work.aeg lavamat error code E20. - _1923.jpg_1924.jpg
Posted on Sep 10, 2011
SOURCE:
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Another AEG e20 Plea, tried everything please help!
E20 on your machine means some sort of drain problem. If it actually goes through the spin cycle fine; some water will still not drain out at the time of the tumble dry. Check the wall drain to make sure it isn't clogged..
Check the drain of your wall, not the washer, this shd be cleaned out thoroughly; and the exit pipe of your washer should not fit too tight into it, there shd be some space for air.
This is a further tip, if helped click helped.
Apr 10, 2013 | Washing Machines
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
AEG Lavamat error E 20? what I have to do?
Hi i have the same problem code E20 what i did to resolve this matter was i popped down to my shed and got my trusted friend the sledge hammer i unpluged the machine and smashed the hell out of it and went and brought a new machine.........
Jul 08, 2009 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
10,058 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
