Question about Nokia BH-503 Bluetooth Headset
Why are bh-503 nokia e63 disconnect
Bh-503 code
SOURCE: i have made connection between
Try manual connecting. If you have paired your x3 and BH-503 before, you should have your paired devices. So after you connect manually, the headphones should connect to x3 next time automaticly. :)
Posted on Dec 26, 2010
esound
  • 425 Answers
SOURCE: pairing pin for Nokia BH-503 and E63
HI,
How to Pair (Connect) a Bluetooth Headset to Your Phone
So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
A
Instructions
Things You'll Need:
* A Bluetooth cellular phone
* A Bluetooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the bluetooth menu.
On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
Thank you using fixya..
Posted on Jan 14, 2011
SOURCE: not found My Nokia BH-503 is not pairing with my
it show bcoz u havnt paired it...pair it by using pasword 0000
Posted on Jul 19, 2011
SOURCE: Compatibility issues between Nokia BH 503 headset
my nokia is having a headphones issue
when i attach headphone wid my nokia 5233 it also show a notification like headset connect bt do not give sound in ear phones
i hav try many compatible headphones but it is still not working
Posted on Sep 15, 2011
casouzaj
  • 1118 Answers
SOURCE: i am not able to
Try to put your headset in pairing mode first. Starting with it turned off, press and hold the multifunction key until the indicator light is flashing quickly in blue. Then, bring your phone and headset close to each other, and, on the phone, go to 'Menu > Settings > Wireless & network' and check the 'Bluetooth' checkbox. Then, tap 'Bluetooth settings > Scan for devices'. After a little while, your headset should appear on the bottom of the screen. Tap over it to make it pair. If a pairing code (or PIN or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is successful, your headset should enter the stand-by mode. It should appear in the paired devices list on your phone as connected. If you tap and hold over it and tap 'Options', you will be able to select your headset services.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if I can assist you any further.
Regards, Carlos
Posted on Sep 18, 2011
My Nokia BH-503 Suddenly Change in to ISSC-SHS and not charging
How long have you had this item? It could be the lithium battery in phone? I would encourage you to take the set up to Batteries etc: and let them check battery. Please leave me some feedback
Jul 08, 2016 | Nokia BH-503 Bluetooth Headset
Could not connect my Nokia Bh 503 Headset to my windows 8 laptop?
It shows Nokia BH-503 Headset installed in View devices in win8 But it doesn't connect. I tried manually connecting in phones it works by pairing. But doesn't get connected in win8. Can anyone help me solve this?
Dec 17, 2012 | Nokia BH-503 Bluetooth Headset
How I can get a Nokia BH-503 driver cd?
How to connect bluetooth headset Nokia BH-503 with Windows 7
I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows.
Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop.
if you want to find your bluetooth devices when you search bluetooth devices from your computer.
- Turn off bluetooth headset.
- Start add bluetooth devices function from your computer for search bluetooth devices.
- Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink).
- You will see Nokia Bluetooth BH-503 in your searching window.
- select Nokia BH-503 device and click "Next" for connect the device
- wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Nov 15, 2011 | Nokia BH-503 Bluetooth Headset
Is symphony FT 40 support nokia BH 503
Please activate the bluetooth on your phone and see if it is pairing . use the pairing code to confirm.
Please check for details from manual:
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-503_apac_ug_en.pdf
Oct 24, 2011 | Nokia BH-503 Bluetooth Headset
BH 503 bluetooth headset is detected on my phone but it doesn't get paired with the 0000 pairing code. Is this a comparability issue. My phone model is Sony Ericsson Satio U1i with Symbian OS.
vsidharth I had the same problem with my satio.. i fixed it,
what to do is pair your bh-503 then click on auto connect.. now click on bh-503 a menu pops up look for set unauthorised.. turn it on
now turn off your ear phones and back on, your satio will say connect, and will now give you the option to enter your pair code 0000.. once you done that, your ready to go.. hope this helps
Jul 14, 2011 | Nokia BH-503 Bluetooth Headset
I tried connecting my nokia bh 503 head set to my HP probook and when it finishes connecting it says device driver not successful
You need to have the bluetooth driver for BH-503. Please find the link on the download site in the link provided below.
http://kamistad.net/free/free-nokia-bluetooth-stereo-headset-bh-503-download
Thanks.
Jul 02, 2011 | Nokia BH-503 Bluetooth Headset
I have made connection between nokia BH-503 and my laptop operating windows 7. But after that when i am trying to connect with my nokia x3 mobile and BH-503 the mobile do not able to find the head set.
Nov 29, 2010 | Nokia BH-503 Bluetooth Headset
Nokia BH-503 Bluetooth Headset Logo
75 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
