Question about Polar Exercise & Fitness
Polar F11 not responding
Hi: I have the Polar F11 for almost 3 years. Back in January I had the battery replaced with an authorized Polar Service Center. The other day I was using my HR Monitor when the screen just froze 10 minutes into the workout. I can't press any buttons to stop the workout or go back to any screen. My question to you is if there is a way to repair it or do I need to get a new monitor?
    Scholar:
  • 157 Answers
Hello glmatta, The unit can be repaired. Remove the units battery. Remove the screws holding the case together. Carefully open the case on a table covered in cloth, T-shirt type cloth, disconnect the flat ribbon cables, lightly clean with a #2 pencile eraser, reinsert cables. Use the same steps on PCbd pin connections. Important question, Do all of the buttons have the same amount of snap when pressing & releasing? If not you have a bad keypad. A bad button swith will cause tis type of malfunction. Contact the Mgfr requesting technical support for possible replacement part and cost.
Posted on Nov 05, 2008
The screen has turned very light to the point where you can barely see the readout.
This sounds like a new battery is needed. To send back into a Polar Authorized service center follow the link here. Yes, you do need to send in to an authorized service center.
Jan 04, 2011 | Polar F11 Heart Rate Monitor
What battery is used in the wrist unit of the Polar F11
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
Feb 23, 2010 | Polar F11 Heart Rate Monitor
My F11 Polar HR monitor is not working correctly
You should have someone who is use to servicing heart rate monitors take a look at it. There are parts in the monitor that can corrode and would need to be cleaned. Also, look into replacing the battery in both units (Strap and wrist) and make sure the unit is reset properly.
Sep 14, 2009 | Polar F11 Heart Rate Monitor
Fading LCD display on Polar F11
I have this problem as well! I was just googling this problem when I found your post. I have the exact same watch and have had it for 2 years. I don't expose it to the sun or heat though.
Jun 13, 2009 | Polar F11 Heart Rate Monitor
How do I change the battery?
Someone posted a link on how to change the batter on an F11. If it's not longer under warranty or you just don't want to bother with sending it back and the extra costs, you could follow this: http://timlaqua.com/2008/09/how-to-replace-the-battery-in-a-polar-f11-heart-rate-monitor-hrm/
Jun 10, 2009 | Polar M32 Heart Rate Monitor Watch
How to change the battery on a Polar F11 Heart Monitor
Here are instructions (with images included) on how to replace the battery for a Polar F11: http://timlaqua.com/2008/09/how-to-replace-the-battery-in-a-polar-f11-heart-rate-monitor-hrm/
Jan 11, 2009 | Polar F11 Heart Rate Monitor
I' advise to start with battery check. If the battery is ok, then you will need a professional to find the cause of malfunction.
Dec 19, 2008 | Polar F11 Heart Rate Monitor
Polar F11 blank display
Sounds to me as the integrated circuit has been damaged.
In this case you will not be able to repair it yourself as watchmakers skills needed.
Dec 13, 2008 | Polar F11 Heart Rate Monitor
POLAR WATCH- F11
try a new battery
Jul 09, 2008 | Polar F6 Wrist Watch
Open Questions:
Hi I have just bought a Sole F85 (2016/2017) treadmill. I was advised it the F85 would work with my Polar H7 and H10 heart rate monitor as these synch with my iPhone and V800 Polar devices H7and H10 are both open source 5kz analogue signal however the F85 does not pick up the signal from the Polar HRM why is this as I was told F85 operates with and can receive a 5kz signal. Polar are leaders in heart rate monitors and all the gym equipment I have used for the past 15 years has been compatible with the Polar Product I am starting to use the Sola Fitnesss application but the F85 Treadmill I have just purchased does not appear in the list for connections there is a blank line which when selected sometimes connect to the F85 via Bluetooth. There appears to be a bug in the software. Also there is connectivity to other apps Fitbit, HealthKit, Mapmyfitness but there is no connectivity to Polar Polar are the leaders in heart rate technology and one of the largest producers of HRM products so when can the Sole Fitness application be developed to include an interface / connectivity with the Polar Flow and Polar Beat applications. Also can the Sole Fitness application be developed so is can use via Bluetooth a Polar heart rate monitor (chest strap)? If Sole Fitness can pick up HRM data from Polars H7 or H10 via Bluetooth then it could be an interface to the F85 Treadmill, is this possible as part of the Some Fitness application development. Also I have noticed that the pulse readout is totally inaccurate as my V800 says 130 bpm and the display on the F85 says 78 Any guidance would be much appreciated
Nov 04, 2017 | Polar Exercise & Fitness
Exercise & Fitness Logo
511 people viewed this question
Top Polar Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
