Question about Altec Lansing BXR1121 2 Speakers
My altec lansing speaker seem to have a problem. the subwoofer is working but the stereo speakers aren't. what's up with that?
The subwoofer is working just fine but the stereo speakers are not working at all. i checked the power supply and the connection from the subwoofer to the speakers, and they're properly connected. now, all i can hear is bass. i even tried the speakers with other laptops and ipods and i keep getting the same results. i need help because these speakers were pretty decent and i don't want to throw them away just yet.
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
SOURCE: Altec Lansing ada745
I work for a charity that had one of these donated today and as I was looking for a new sub for my cinema system I purchased it. I have no other speakers with it and no way of switching or varying the volume. I opened up the back of the sub and slid the board partly out exposing the PCB.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3734.jpg[/IMG]
You'll see 3 solder connections behind the scre in an "L" configuration. One of them is common, one volume and one power on. As I don't need volume, I'm happy with it being on full as my cinema system will vary the input, I joined all 3 together giving power on and full volume. It is working great now.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3737.jpg[/IMG]
For you guys with volume controls, I would suggest shorting out the two rightmost pins in the "L" and I recon this will power it up and try varying your volume control. I recon it'll work just great.
Good luck
Posted on Jan 22, 2009
edwinmeyer
  • 57 Answers
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 22, 2009
  • 185 Answers
SOURCE: Need the pairing code for bluetooth device to my Altec Lansing
Hi if your intentions are too connect your Phone to that bluetooth device , The paring code is what you make it , when you connect the two device's together , When you search for devices it will ask you to pair with that device , and you make the code anything you wish....Otherwise have a look at the manual under connection , it should have .
I hope this helped bud
Happy new year
Posted on Jan 01, 2010
Altec lansing acs33
the subwoofer plugs into the wall on a 110 volt outlet. then use mastervolume control.. RANDY
Apr 28, 2014 | Altec Lansing Multimedia Computer Speakers
I want to connect ADA-995 speaker system to stereo
You don't. They're already amplified via the amp that's inside the subwoofer. They're only designed for a headphone output on a PV or portable audio player
Apr 03, 2014 | Altec Lansing Audio Players & Recorders
Altec lansing ATP4 speakers aren't working
is it possible that you may have plugged the speakers into the microphone or audio input jack on the computer instead of the speaker/headphone/audio output jack?
Apr 28, 2017 | Altec Lansing Audio Players & Recorders
Can I connect this to my tv? If so how-can't figure out how.
Sure, if your TV has some kind of audio outputs (and volume controls) for the "audio 5.1 inputs" you see in this picture.
http://rosario-cavite.olx.com.ph/altec-lansing-vs3251-5-1-speaker-rush-3-8k-19-days-old-iid-24919817#pics
You COULD adapt the probably-present stereo audio from your TV for use with the front channels . Stereo.
May 12, 2011 | Altec Lansing VS3251 Speaker
Altec avs500 speaker sound in 2 speaker only and not the rest
Try making sure the surround sounds knob is turned all the way to the right and that the switch on the subwoofer is on stereo and not gaming.
Mar 13, 2009 | Altec Lansing AVS 500 Computer Speakers
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
May 15, 2008 | Altec Lansing Multimedia Computer Speakers
Surround wont work
try and download sound softwares from majorgeeks.com.
hope this works.
Jan 05, 2008 | Altec Lansing VS3251 Speaker
Altec Lansing BXR1121 2 Speakers Logo
43 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
