Question about Kenmore 93812 / 93814 Electric Kitchen Range
Kenmore Elite 790 flashing 'door locked' and LOC
The door is locked with a flashing 'door locked' and LOC. I can depress the STOP/CLEAR for 3 seconds and the door will unlock. However, the flashing 'door locked' and LOC remain. If I now open the door, 'dr' is displayed along with the other displays. When I now close the door the time replaces the 'dr' but the other displays remain and the oven is non-functional.
SOURCE: my oven says LOC and it is not locked
Today the "Loc" light came on and I can not use
the oven... the oven door does open and the
cook top works ok?
I see two others have the same problem.
I tried to un-plug the electric plug but this did
not re-set it?
This unit is about 7 years old. I can not find
the manual. There is no re-set button anywhere
and I also can not find a model number on back?
Posted on Mar 09, 2008
  • 413 Answers
SOURCE: I have a kenmore elite
The range has entered sabbath mode. Refer to owners on procedure for turning sabbath mode off. Also try to hold down "timer off" button for 10 seconds.
Posted on Jun 09, 2008
  • 148 Answers
SOURCE: Kenmore elite 790 79363400 dual fuel oven door does not close all the way a
if your locking it to make the light goes off it sounds more like the light switch on the oven needs to be replaced
Posted on Jul 08, 2008
SOURCE: Kenmore 790 Oven Locking mechanism problem
I had the same problem. Open the oven door. Press and hold the light switch. You will hear the door lock move back into the correct position. Hope this fixes your problem. This has happened to me twice and holding the light switch always works.
Posted on Sep 25, 2008
SOURCE: kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Posted on Dec 17, 2008
What does LOC mean on kenmore elite washer ?
Press the Options and Select buttons at the same time and hold for 3 or 4 seconds to unlock the control panel. Best Wishes
Sep 04, 2014 | Kenmore Washing Machines
Flashes LOC and won't start
The solution to the "LOC" error depends on many factors, including which Elite model machine you own and the cause of the error. If your machine has an "Options" and a "Select" button, try pressing and holding these for five seconds to clear the locking error. You can also try unplugging the machine for five minutes and then plugging it back in
Nov 08, 2012 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite oven door is locked and I am getting an F93 error message. I have had repairmen here 3 times already to fix the problem. Can you help?
The F93 - Maximum oven door lock time exceeded. First thing to try is holding the clear button down for 3-5 seconds sometimes this unlocks the door and then leaves the loc light still on in this case you would open the door and once again hold down the clear to make the loc light clear. If your unit doesnt have a clear button then you would hold the stop button for the same amount of time as described above. If this doesn't work try shutting off the power at your electrical breaker for 7 minutes this usually causes the control to reset in the unit. If you have any further questions or if this does not work to allow you to be able to open the door and clear the error code message me back for further diagnosis. Thanks
Sep 03, 2011 | Ovens
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    unplug for 40 minutes and re-try.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Aug 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    hold down the stop/clear button for 3+ seconds
    Jan 13, 2009 | Kitchen Ranges
    Kenmore elite 790.3670 oven door locked
    I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
    Feb 07, 2008 | Kitchen Ranges
    Kenmore Elite Electric Range, Display stuck on LOC
    I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
    Feb 03, 2008 | Kitchen Ranges
    Kenmore Elite Range door locked error message
    Hold down the number three button until the LOC message disappears and then the door will open.
    Dec 23, 2007 | Kitchen Ranges
    Kenmore 93812 / 93814 Electric Kitchen Range Logo
    41 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Sal De
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
