Question about Toshiba E-Studio 3511 Color Copier
Toshiba e-studio 351c gives me a C010 error, - Toshiba E-Studio 3511 Color Copier
5 Suggested Answers
  • 46 Answers
SOURCE: Toshiba Studio 351c Call for service
You need to post the error code (top right hand corner of the screen
Posted on Jun 11, 2009
  • 653 Answers
SOURCE: my Toshiba e-studio 3511 gives me a C010 error,
C010 indicates main motor abnormality.
U need to perform output check 03-101(ON)/151(OFF) to off the main motor. If main motor not running under output test, probably u need to replace it.
If motor working, u might need change the LGC board.
Posted on Jun 24, 2009
  • 10 Answers
SOURCE: Toshiba e studio 351c need firmaware
It depends what the copier is doing, is it giving error codes
one of the main faults on the copier is it dumps colour toner and that causes problems
need more info
Posted on Jul 02, 2009
  • 9 Answers
SOURCE: We replace the used toner
There is a sensor just behind the waste toner box that sends beam through the water toner box to see if reaches the other side. If it does not, then the sensor thinks that the box is full. So you need to clean the waste toner box with some liquid cleaner so that it looks white from outside. Once the box is dry, try again. This should work now. Otherwise, there is problem with the sensor.
Posted on Sep 24, 2010
What can i do for toshiba 281c is giving me error code c010?
I don't think that's a valid code. Perhaps CD010? In which case there's a problem with the cleaning brushes.
Apr 06, 2015 | Toshiba E-studio 281c Copier
Call service c010
Hi and welcome to FixYa.C010 is a motor drive failure or abnormality. Check for a major paper jam in the drum area or any problems with belts or rollers AFTER your remove the drum. Look for any foreign objects in the belts or plastic gearing. The C101 code usually will appear right after the unit reaches operating temps. After checking for any jams and re-installing the drum. Use your manual and perform the motor output test. 03-101 (Motor on) / 151 (motor off) If the motor runs during this test you may need to change the LGC board. You will see this response for almost every Toshiba C010 error here at FixYa.
Thanks for choosing FixYa,
Aug 12, 2012 | Toshiba E-STUDIO 450 Copier
I have a toshiba e-Studio 351c show E030 , i was remove the paper jammed but the machine not work and still show E030
clear very well the paper path especially if there is bridge who trasfer the paper to the finisher and check the sensor inside it or check if there is any load at the main motor
Nov 30, 2011 | Toshiba e-Studio 350 Copier
C010
Hi and welcome to FixYa. I am Kelly. C010 is a motor drive failure or abnormality. Check for a major paper jam in the drum area or any problems with belts or rollers AFTER your remove the drum. Look for any foreign objects in the belts or plastic gearing. The C101 code usually will appear right after the unit reaches operating temps. After checking for any jams and re-installing the drum. Use your manual and perform the motor output test. 03-101 (Motor on) / 151 (motor off) If the motor runs during this test you may need to change the LGC board. You will see this response for almost every Toshiba C010 error here at FixYa.
Kelly
Nov 04, 2010 | Toshiba E-STUDIO 450 Copier
Que significa el error C010 en toshiba est 280 por favor alguien se lo sabe, gracias i.b
C010 indicates main motor is abnormal.
Is the main motor working? (Perform the output check in the test mode: 03-101/151)
If main motor working, check the feeder's clutch, whether it is hard.
Oct 23, 2010 | Toshiba e-Studio 350 Copier
Estudio350 with error c010, checked the fuser, drum unit , dev unit, all are turning freely, error comes on as soon as fuser comes to full temp
Hi
Error C010 indicates main motor fault. Please check the main motor. If main motor not running under output test, then you'll need to replace it. If motor working, u might need change the LGC board. Take the drum unit out and check inside for any irregularties in drive system belts.
Hope this helps...
Daniel
Sep 30, 2010 | Toshiba E-Studio 3511 Color Copier
My Toshiba e-studio 3511 gives me a C010 error, what does that mean??
Jun 24, 2009 | Toshiba E-Studio 3511 Color Copier
Had a power outage, not a surge, now reads call for service.
Press "clear" and "8" simultaneously and hold, this should display the error code...what is the error code?
Jun 14, 2009 | Office Equipment & Supplies
need more info
Jun 12, 2009 | Toshiba e-Studio 350 Copier
Toshiba E-Studio 3511 Color Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
