Question about Husqvarna Viking 1
Feed dog switch
Help when cleaning my Husqvarna Viking 940 using switch to lower feed dog to remove stitch plate it worked. But after cleaning and replacing stitch plate the feed dog switch doesn't raise the feed dog to enable material to be pulled through.Any solutions.
  • 5 more comments
  • lacebobbin Nov 05, 2008
    Did not solve the problem so has had to go in to service engineer Thanks for idea
  • Anonymous Mar 16, 2014
    the needle plate on my Husqvarna Viking E10 fell off and i looked through the users guide but it won't help so can you?
  • Anonymous Mar 22, 2014
    Who can I the material feed plate to come up?
  • Anonymous Mar 25, 2014
    How do you lower the feed dogs
  • Anonymous Mar 27, 2014
    I canL-
  • Anonymous Mar 29, 2014
    I was sewing along and raised the foot to move my material when I went to lower it, it stuck a quarter inch above the feed dogs
  • Anonymous Mar 30, 2014
    It started making the noise after I switched the feed dogs to do a rolled hem.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
Hi, Janome 124 - top thread picks up the bobbin thread, motor sounds good. Th feed dogs won't pull fabric (or paper) thru the machine - dogs don't stick up much above the plate. Help please! Jan
Remove the needle plate and clean the feed dogs with a brush...remove any lint and bits of thread.
A couple of drops of sewing machine oil might help to loosen the feed dogs up. (maybe let the oil seep in and then turn the handwheel towards yourself to help things along.
One other thought:
If your machine has feed dog lowering capability you might want to move that lever/switch back and forth a couple of times.
The feed dogs might not appear to raise or lower, but some machines will only re-engage raised feed dogs when the machine starts to stitch.
Also...verify that the presser foot tension isn't too strong/heavy...and temporarily try using a longer stitch length setting.
Mar 19, 2017 | Janome Sewing Machines
Stitch length stuck husqvarna
Remove the needle plate and make sure there is no lint obstructing the feed dogs. If they are clear, it is usually the feed dog step motor gone bad. You should have your machine serviced by an authorized Husqvarna Viking dealer. You can find your nearest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Sep 26, 2014 | Husqvarna Sewing Machines
Feed dogs not pushing fabric through
Sep 26, 2014 | Husqvarna Viking 1
Feed won't move fabric
Feed dogs in the up position? Most machines have a switch to lower the feed dogs for free motion or embroidery! If switches in correct position then remove your stitch plate and clean out all fluff built up between the stitch plate and the feed-dogs. If none of these: dealer time.
Dec 02, 2013 | Baby Lock Esante
I need to know how to lower the feed dogs on my Huskystar Viking E10
There is a switch on machine to raise feed dogs up/down. Remove any extension table to locate it because many of these options are located in the back of machine & hidden by table! Jimmy :)
Apr 07, 2012 | Husqvarna Sewing Machines
The feed dogs will not come back up to the proper height after lowering them to do a button. How do I get them to come back up. I tried the dial, which has worked in the past.
You will need to move the stitch dial/slide/button back to normal stitching position but also actually try to sew on it.
The feed dogs will not return to normal postion until machine has gone through a full stitch sequence so they may look like they haven't returned up. Just put some fabric under the foot, lower the pressure foot and try stitching a stitch or two.
Oct 10, 2011 | Husqvarna Viking 1
Stippling for Viking emerald sewing machine
The switch in the back will lower the feed dogs.
If you need a manual - I found a PDF download by googling: viking emerald 183 manual
Feb 23, 2010 | Husqvarna Viking 1
Removing needle plate from viking sewing machine
throat plate is usually tight with screws may be that the holding magnet and once the button is located near shuttle and it should press plate up...
Dec 24, 2009 | Husqvarna Viking 1
Sewing Machines Logo
979 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
